Nearly went over.
   / Nearly went over. #51
I have the hammers. They do a beautiful finish cut on green grass. Mind you mine cut everything. :).
   / Nearly went over. #52
I’m looking to have a flail chop up small forest stuff for the purpose of reducing fuel. Think this will do well?
   / Nearly went over. #53
Mine chops green stuff up pretty good up to about 3/4" without hurting the hammers. Dry hard stuff it smashes and splinters up. I try not to use it on dry brush as maintenance would ultimately be higher. It chops lantana pretty good. In the 4 or 5 years I've had it I have sharpened the hammers properly just once. Gave them a touch up after some hard work another time. If you are doing brush then you will have to touch up your hammers if you plan on doing grass after.
   / Nearly went over. #54
Rear wheel weights or loaded tires do nothing for ballast.
Loaded tires, the added weight is resting on the ground, not added to the frame. A rollover has to lift the extra weight beyond the tipping point. It does add some FEL ballast and lessens the chance of a rollover. I use loaded tires and 3pt ballast to keep my shorts where they belong.
   / Nearly went over. #55
Why do you load tires if not for ballast? Using my 3301 with unloaded tires was like a carnival ride until I bought wheel weights; the rears were constantly coming off the ground. They still come up a bit easier than I would like but it's better than what it was.
   / Nearly went over. #56
Tractor loader funny situation, boils down to 2 levers acting in opposition. Some argue is worst possible combination but one dat works best. Look at some de early cable loaders on tractors and argument pretty good.
Back few years used to be able to grab lot of spare tires companies hung under trailers pulled by owner operators at truckstops. OO used to help dem fall off rack to cut weight he pullin. Dey real poor fer tire, but dey hold air. Best had tubes. Really good fer weight in back of pickup fer winter traction, better if air replaced wid water. Even better fer counterweight on back of tractor wid loader.
Make pipe slips thru centerhole of wheel fer tire to ride on and you got maybe 800 pound counterweight you can easy mount er dismount as mood makes you in. Makes good back bumper too. Carry low fer best result.
   / Nearly went over. #57
The posting style of a single member is not the topic of this thread.
Amen. People should realize there is also a block function.
As for the OP topic, I rolled my tractor not too many months ago. So I understand. For me it was a task I had done a thousand times before. I just got too complaicant and the right front wheel got up in the manure pile and was enough to send me over. Rear tires are now loaded with Rim Guard. Also if I have a lot of loader work to do I hook up the tiller as extra ballast. That is 600 pounds against a lifting capacity of 1000 pounds for my loader. Makes everything much more stable.
Your 500kg addition will help. That and the loaded rears that you already have are a good thing.
   / Nearly went over. #58
Filled tires don't do much for lifting. You need weight on the 3 point.
My tires were not loaded until after I rolled the tractor. I would disagree. The tire is heavier now than it was and thus harder to get off the ground. It lowers the center of gravity of the tractor so makes it harder to tip.
It is not the end all be all and sufficient weight on the 3 point is certainly in order. OP is talking about adding just over half the weight of the item he is lifting to the 3 point. That will help out quite a lot.
   / Nearly went over. #59
Traction. We have to remember that tractors were originally designed for pulling and were 2wd.
   / Nearly went over. #60
As far as I am concerned he should be banned from the forum, it's quite obvious he does it intentionally. His post are nothing but spam at this point as I don't read them either. I plan to start reporting them as well.
Really? what are you going to report? that he talks different than you?
Just skip past like others do.
UNUSED 20 in. Gasoline Chain Saw (A53117)
UNUSED 20 in...
2008 KZ Sportsman Police Bunk 5th Wheel Tri-Axle Travel Trailer (A51694)
2008 KZ Sportsman...
2016 John Deere 17 Mini Excavator (A47477)
2016 John Deere 17...
FORD COBRA REPLICA RACING CAR (A53426)
FORD COBRA REPLICA...
JOHN DEERE 1705/6700 LOT NUMBER 20 (A53084)
JOHN DEERE...
