820 (3 cylinder) broken left brake line
   / 820 (3 cylinder) broken left brake line #1
2345joes
Member
Western Oregon
John Deere 820
In the process of changing the hydraulic filter I broke the left brake line. I have a replacement in order AR65686.
Any tricks to bleeding the lines. Is this more difficult on an open hydraulic system?
thanks again,
Joe
arrow points forward
   / 820 (3 cylinder) broken left brake line #2
Bleeding brakes is similar on open & closed center hyd systems. Both types require engine to be idling so trans pump can replenish brake valve reservoir with hyd oil.
Thanks Again!
   / 820 (3 cylinder) broken left brake line #4
You're welcome
   / 820 (3 cylinder) broken left brake line #5
When I bleed the 2030's brakes, I use clear tubing, run to the transmission filler.
I had to replace a left brake line. It was kinked (guess a stick hit it?) I was surprised the replacement came prebent and fit very well.
Thanks you!
Thanks for the help! The line from JD fit perfectly. I bleed it with a loose fit of the nut, 4 or 5 partial brake pumps, then tightened. It works great!
I had a little trouble with the hydraulic filter (as you can see) and kept trying to seat the rubber gasket on top of the housing bowl. I tore up 2 and lost a lot of fluid before I realized it needs to be seated on the tractor side... or at least that was what worked for me.
   / 820 (3 cylinder) broken left brake line #9
I did the same thing the first time I did a filter change. I thought I had the wrong packing and went and bought second one. Service Manager told me the right way to install.
I had oil EVERYWHERE!!!!
30pc. 16ft.x 3ft. Black Metal Roof Panels (A55758)
30pc. 16ft.x 3ft...
(APPROX 7) 8" I BEAMS UP TO 10' (A54756)
(APPROX 7) 8" I...
2021 CATERPILLAR 242D3 SKID STEER (A51406)
2021 CATERPILLAR...
2016 Toro Groundsmaster 7200 Zero Turn Mower (A55851)
2016 Toro...
UNUSED LANDHONOR 11' X 19' ALL-STEEL CARPORT (A54757)
UNUSED LANDHONOR...
2012 Cadillac SRX SUV (A55758)
2012 Cadillac SRX...
