820 (3 cylinder) broken left brake line
   / 820 (3 cylinder) broken left brake line #1
2345joes
Member
Western Oregon
John Deere 820
In the process of changing the hydraulic filter I broke the left brake line. I have a replacement in order AR65686.
Any tricks to bleeding the lines. Is this more difficult on an open hydraulic system?
thanks again,
Joe
arrow points forward
   / 820 (3 cylinder) broken left brake line #2
Bleeding brakes is similar on open & closed center hyd systems. Both types require engine to be idling so trans pump can replenish brake valve reservoir with hyd oil.
Thanks Again!
   / 820 (3 cylinder) broken left brake line #4
You're welcome
   / 820 (3 cylinder) broken left brake line #5
When I bleed the 2030's brakes, I use clear tubing, run to the transmission filler.
I had to replace a left brake line. It was kinked (guess a stick hit it?) I was surprised the replacement came prebent and fit very well.
Thanks you!
Thanks for the help! The line from JD fit perfectly. I bleed it with a loose fit of the nut, 4 or 5 partial brake pumps, then tightened. It works great!
I had a little trouble with the hydraulic filter (as you can see) and kept trying to seat the rubber gasket on top of the housing bowl. I tore up 2 and lost a lot of fluid before I realized it needs to be seated on the tractor side... or at least that was what worked for me.
   / 820 (3 cylinder) broken left brake line #9
I did the same thing the first time I did a filter change. I thought I had the wrong packing and went and bought second one. Service Manager told me the right way to install.
I had oil EVERYWHERE!!!!
2015 Hyundai Sonata Hybrid Sedan (A55758)
2015 Hyundai...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
KIDS DIRT BIKE (A55758)
KIDS DIRT BIKE...
2011 INTERNATIONAL PROSTAR TANDEM  AXLE MID ROOF SLEEPER (A54313)
2011 INTERNATIONAL...
1999 FORD F550 BOX TRUCK (A54313)
1999 FORD F550 BOX...
2008 JLG 1930ES ELECTRIC SCISSOR LIFT (A52705)
2008 JLG 1930ES...
