820 (3 cylinder) broken left brake line
   / 820 (3 cylinder) broken left brake line #1
2345joes
Western Oregon
John Deere 820
In the process of changing the hydraulic filter I broke the left brake line. I have a replacement in order AR65686.
Any tricks to bleeding the lines. Is this more difficult on an open hydraulic system?
thanks again,
Joe
arrow points forward
   / 820 (3 cylinder) broken left brake line #2
Bleeding brakes is similar on open & closed center hyd systems. Both types require engine to be idling so trans pump can replenish brake valve reservoir with hyd oil.
Thanks Again!
   / 820 (3 cylinder) broken left brake line #4
You're welcome
   / 820 (3 cylinder) broken left brake line #5
When I bleed the 2030's brakes, I use clear tubing, run to the transmission filler.
I had to replace a left brake line. It was kinked (guess a stick hit it?) I was surprised the replacement came prebent and fit very well.
Thanks you!
Thanks for the help! The line from JD fit perfectly. I bleed it with a loose fit of the nut, 4 or 5 partial brake pumps, then tightened. It works great!
I had a little trouble with the hydraulic filter (as you can see) and kept trying to seat the rubber gasket on top of the housing bowl. I tore up 2 and lost a lot of fluid before I realized it needs to be seated on the tractor side... or at least that was what worked for me.
   / 820 (3 cylinder) broken left brake line #9
I did the same thing the first time I did a filter change. I thought I had the wrong packing and went and bought second one. Service Manager told me the right way to install.
I had oil EVERYWHERE!!!!
KODIAK 10' HD ROTARY MOWER (A51406)
KODIAK 10' HD...
2017 SKYJACK SJIII4740 ELECTRIC SCISSOR LIFT (A52705)
2017 SKYJACK...
2020 TAKEUCHI TB240 EXCAVATOR (A52705)
2020 TAKEUCHI...
2010 GMC Acadia SL SUV (A55758)
2010 GMC Acadia SL...
Demco 365 Gravity Wagon (A50775)
Demco 365 Gravity...
