Did the Covid shot make you cranky?
Status
Not open for further replies.
   / Did the Covid shot make you cranky? #213
   / Did the Covid shot make you cranky? #214
I’m not going to find out.
   / Did the Covid shot make you cranky? #216
   / Did the Covid shot make you cranky? #218
Well, at least you recognize it. That's good.
When I had COVID, I just wanted to sleep all the time. Head felt like I was under water too long, with stuffed up ears and sinuses for about 5-7 days. Got really tired doing anything. That was in Nov/Dec. Took about 3-4 weeks to feel like myself again. When I got the shots last month, the first one, I was fine for 12 hours, then felt like I had COVID again for about 12 hours, then was back to fine again. 2nd shot I had no effects other than a bit lethargic the next day. Sore arm at the shot location though, both times, for about 2-3 days.
Almost no one I know had the same symptoms as the next person for both. COVID and/or the shots. It really isn't a cookie cutter illness. My wife had COVID at the same time I did, and just last week she said things no longer smell like cigarettes. That was 4 months before things started smelling better to her.
Good luck with your symptoms. Most people I've spoken with had different reactions to 1st and 2nd shots, so you'll probably be fine 2nd time. (y)
So, you had corona virus, then you got the shots, then you felt bad. You'll likely die of something completely different which will be recorded as cororna virus on your death cert. Why did you get the shots after you already had survived?
   / Did the Covid shot make you cranky? #219
Just waitin' for Flat-Earthers to check in.
btw, there's a lot of plain old flu going around in Brazil, Michigan, and India lately. Did we ever get the true mask death numbers, or have they been fudged too?
(OT: I have enough masks to last until the next election. Not a statement, 'just in case'. Still haven't died from getting my shots.)
   / Did the Covid shot make you cranky? #220
Still classy....
Status
1998 CAT D5M XL (A55272)
1998 CAT D5M XL...
New/Unused SD Lanch 20x20 Carport (A57454)
New/Unused SD...
PAZA 3PT SPIN SPREADER (A52708)
PAZA 3PT SPIN...
2007 Ford Ranger (A56858)
2007 Ford Ranger...
2020 CAT 308 (A53317)
2017 Freightliner M2 106 AWD Terex Hi-Ranger 5TC55 55ft. Insulated Material Handling Bucket Truck (A55973)
2017 Freightliner...
