Modified my drawbar to actually be useful
   / Modified my drawbar to actually be useful #1
Smokeonthewater
2010d
Needed to hook up to a utility trailer for serious tractor work.... hay ride for the kids.... not a fan of 3 pt drawbars and the stock one is about useless in stock form.... soooo I started cutting and welding... VERY pleased w my results....
Obviously the added length would reduce vertical capacity but I won't have more than a couple hundred lbs of tongue weight...
Forgot to mention... in the pics above the drawbar is in the extended position... can retract and use the other hole if wanted
   / Modified my drawbar to actually be useful #3
That's a good idea that works. Plus, anytime you can cut and weld is a plus.
   / Modified my drawbar to actually be useful #4
pretty cool. And welding is fun.
   / Modified my drawbar to actually be useful #5
Obviously the added length would reduce vertical capacity but I won't have more than a couple hundred lbs of tongue weight...View attachment 699033
Looks as if you machine came WITHOUT the OE tow bar. Item-6 can be a regular tow-ball.
No it came WITH it and it's still there....
Problem w item 6 is that it's too far forward and the tires get into the trailer on turns
   / Modified my drawbar to actually be useful #7
Yes, the system is designed to extend and retract. Here's all the details from Fredricks Equipment Catalog on Parts.
   / Modified my drawbar to actually be useful #8
OK.
I got an extender from Harbor Freight. :)
   / Modified my drawbar to actually be useful #9
Notice the machine needs a PTO shield. Not only for safety, but to prevent the top-link from falling down upon a PTO shaft causing damage. I can't count how many times that simple shield saved my PTO shafts from getting banged up.
Yeah before even in the extended position it wasn't extended enough...
I'm curious what you used from HF to extend yours...
2025 CFG Industrial MX12RX Mini Excavator (A59228)
2025 CFG...
2017 Nissan Altima 4 door (A56438)
2017 Nissan Altima...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A56857)
2020 Caterpillar...
2011 Toro Multi Pro 1250 Sprayer Cart (A59228)
2011 Toro Multi...
2018 ARIENS RIDING MOWER (A56859)
2018 ARIENS RIDING...
2007 MACK CV713 ELITE DUMP TRUCK (A60430)
2007 MACK CV713...
