Tool box for compact tractor
   / Tool box for compact tractor #1
Alan46
Elite Member
Estacada Oregon
KiotiCK25 HST
Hi all, I have a Kioti ck25 compact does anyone have any photos of a toolbox mounted somewhere on a compact tractor or an idea of what to use and where to mount it? Thanks in advance......🇺🇸✌🏻
Quote Reply
Report Edit Delete
Lots of folks replace the right-hand step with a toolbox. The step is worthless when you have a loader because the joystick is in the way.
Thanks for the reply. I'm going to install a wood platform to that small step so I can fasten my tool box to it!☮✌🏻
   / Tool box for compact tractor #4
I plan on eventually removing the right hand step completely and using the existing mounting holes to add a fabricated tool box bracket. I plan to cut up the step to widen the step on the left side. Existing step is to narrow when wearing heavy boots.
   / Tool box for compact tractor #5
I made a holder for a 20mm ammo can on my tractor. It serves as a step with the box removed. Downside is I can’t open the door with the can in place. My property is pool table flat, so needing the right door as an escape route doesn’t really concern me.
   / Tool box for compact tractor #6
Very nice job.
   / Tool box for compact tractor #7
Yes - that's a fine job. Looks OEM. A suggestion - keep a close eye on the box. If it rattles, shakes, etc - might be good to put a single strip of sticky backed foam tape on the box lid. Don't want the top of the box making direct contact with the glass door. Better to have a foam strip as a buffer.
   / Tool box for compact tractor #9
We chose to make our tool box a removable platform. It rests on the ROPS mount and wraps the ROPS bar but stays in place beautifully. We carry tools, chains, rope, and miscellaneous pins and such. We can add a third box if needed.
   / Tool box for compact tractor #10
Lot good ideas have been posted...try SEARCH.
John Deere 690B Excavator with Auxiliary Hydraulics (A57024)
John Deere 690B...
Adams Tender / Magnolia Trailer (A56436)
Adams Tender /...
2023 Kubota Z412KW-48 Commercial Zero Turn Mower (A56436)
2023 Kubota...
2020 INTERNATIONAL MV607 26FT NON CDL BOX TRUCK (A59575)
2020 INTERNATIONAL...
Zero Turn Mower (A59228)
Zero Turn Mower...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
