arto98607
- Joined
- Aug 27, 2014
- Messages
- 1,518
- Location
- Southwest WA
- Tractor
- Kubota F3060, Grasshopper 721D, Ford 1310, John Deere 440 ICD, John Deere 300 & 430
.......................snip..................... The cut is pretty good but I think could be better. Or at least it seems so the way people rave about these things!
I'll replace blades if not too costly but if it gets up there I'll save the cost for a new 5 foot flail mower.
I ran this one into 3 foot grass and it didn't bog at all. Cut left something to be desired but the grass is wet.
Cut depth set at 2 1/4 inches.
The cut looks OK for a field or yard in the first photo, but if you are cutting 3 foot tall wet grass (hay ??) you probably need to slow down the ground speed, or do another quick run day or two later once the grass has dried.
The cut finish should look like something in-between finish mower and brush hog I think.
