Adding a step on the right side of a CK2610
   / Adding a step on the right side of a CK2610 #1
mangler
Gold Member
Ontario, Canada
Sears G5500, Kioti CK2610
Has anyone done this on their CK series tractor? With fender mount loader controls there is plenty of space to get on from the right side. Only 60 hrs in I can't count the number of times I "hoisted" myself on the right side already. Step is like 60$, just wondering if anyone has installed it on the right side yet, how it fits etc.
   / Adding a step on the right side of a CK2610 #2
I'm thinking of doing the same once I get mine. I have the loader controls in the way on mine, but I don't think it will be a big deal squeezing past it...
   / Adding a step on the right side of a CK2610 #3
weird, my dk45 has steps on both sides. i thought the ck series would also have them. im sure you T4620-70221could make one yourself or have someone fab one up. I see Michigan iron sells them
T4620-70221
They probably cheaped out on the new CKs. I believe the DKs are a higher end model. Yours probably even came with a stock floor mat!
   / Adding a step on the right side of a CK2610 #5
Yes it did. And 3 cup holders...
and even a mp3 player cord by one cup holder.
   / Adding a step on the right side of a CK2610 #6
DKs actually have less niceties and options stock from what I saw (cabs get you all kinds of nice add-ons, for all models). They are a heavier tractor so leave stuff out so the price jump isn't as bad. I do sometimes wish for a right-side step as well.
But hey, my CK SE came with a floor mat ;)
   / Adding a step on the right side of a CK2610 #7
If you plan on adding Kioti 3rd function remote you'll see the connections are mounted right where the step on the right side would be.
The third function runs my grapple and my snow plow.
   / Adding a step on the right side of a CK2610 #8
Mangler, yes, I did this on my 2018 CK3510SE HST as one of the first mods. Also installed one on a buddy's identical tractor. The step as a separate add-on part is identical to the left-side step, but is Kioti gray. If you found it for only $60, that's a bargain. Mine was about $93!
It bolts right up to the pre-existing holes, with four hex-head metric cap screws that you can source locally. But, there is a factory-installed bracket that must be bent slightly to avoid interference. See attached pic. The bracket is probably there for future installation of a proprietary Kioti 3rd Function kit that was just becoming available at the time, so Wassup8687's caution is well taken! In my case it was a non-issue because I have a dealer-installed W.R. Long 3rd function, which does not use the bracket. In fact, the bracket was used only as an attachment point for the hydraulic lines with cable ties.
I reported on this in a TBN thread in June 2019, in more detail. Here's the link: Anyone put a step on the right side of a ck3510?
Let us know how you make out.
Well I bent my left side step today (aggressive trail blazing, too lazy to cut enough stumps and branches), so I may be reconsidering the right one. Thanks for the detailed description though, it's nice to know it will fit, even if it needs a bit of fiddling. Jumping off the tractor on the right side is a sprained ankle waiting to happen.
   / Adding a step on the right side of a CK2610 #10
Just bought a ck2610h and had the dealer add the right step. The price was bundled in with the floor mat, pats quick hitch, arm rest and link throttle. I have no idea how much i was charged for it.
   / Adding a step on the right side of a CK2610 #11
When I was shopping tractors the CK10SE series had all kinds of goodies... dual rear remotes, floor mat, telescoping link kit. On the other hand, the DK4510 was only about a $1,000 more than the CK4010SE. I was able to add the same goodies onto the DK for a couple thousand.
I think the DK45 had more features than the DK4510 series.
   / Adding a step on the right side of a CK2610 #12
unclesalty-Can you post a picture of the mounting location of the step you have on the right side of your CK2610?
I’m confused on this. My dealer said (as of yesterday) there is no right-hand step available, and claimed to have discussed with the Kioti Rep. Here’s a picture of my right-side frame, and there are no holes that I can see to mount a step in a similar fashion to how the left side is done.
Did the frame change on the latest models? Mine is a 2019.
Thanks, Toukow
   / Adding a step on the right side of a CK2610 #13
Thanks, Toukow
There's a square bar up under the deck lip on mine, the same as the other side with the same 4 step mounting holes. 2020/2021 model, so there was probably some change from 2019 to 2020.
   / Adding a step on the right side of a CK2610 #14
My CK25 came with steps on both sides and the floor mat but I only have 1 cup holder, but I mostly use it to put my phone in so I don't run it over..................................again.
   / Adding a step on the right side of a CK2610 #15
This is the same configuration on my 2018 CK3510SE HST. Here are three more pics of my add-on right side step, from slightly different angles. Toukow, it looks like the set-up on your 2019 CK2610HST is indeed different from Midniteoyl's and my CK3510SE HST models. So it could a matter of frame size. Or maybe the SE designation, though I think that's less likely. But, then, Unclesalty just bought a CK2610HST, and the dealer was able to add a step. Maybe an older model-year? I've just assumed it's a late model. Hopefully he can post a pic of his right-side step set-up and solve this mystery. :)
   / Adding a step on the right side of a CK2610 #16
adfd
........This is the same configuration on my 2018 CK3510SE HST. Here are three more pics of my add-on right side step, from slightly different angles. Toukow, it looks like the set-up on your 2019 CK2610HST is indeed different from Midniteoyl's and my CK3510SE HST models. So it could a matter of frame size. Or maybe the SE designation, though I think that's less likely. ........
Thanks for the education. I had always had taken the passing comments that the 3510 and 2610 were the same tractor, except engine size. I guess there are other differences as well. If my list of 'to do's' gets too low, I'll consider trying to fabricate something for mine. Thanks, Toukow
167 (A52708)
167 (A52708)
2022 Club Car Tempo Cart (A55852)
2022 Club Car...
5th Wheel Hitch (A59230)
5th Wheel Hitch...
2008 GMC C7500 CREW CAB FLATBED DUMP TRUCK (A57192)
2008 GMC C7500...
2001 JOHN DEERE 310SG BACKHOE (A60429)
2001 JOHN DEERE...
2022 Chevrolet 1500 Silverado Crew Cab 4X4 Pick-Up Truck (A59230)
2022 Chevrolet...
