Maytag (dryer) repair question.... works but no heat
   / Maytag (dryer) repair question.... works but no heat #31
   / Maytag (dryer) repair question.... works but no heat #32
Ive never seen a dryer get a 40 amp breaker. There always rated 30 amp. And if it is run with #10 wire it should not be breakered above 30 amps.
   / Maytag (dryer) repair question.... works but no heat #34
With luck my washer - dryer pair will last 20 -25 years. I don't even know if a repair man would come out this far. If he would - the cost would probably give me a stroke.
I just buy a new pair and move on. Same with the water heater.
   / Maytag (dryer) repair question.... works but no heat #35
LOL - easy fix after all. While you are at it, since you have to power down anyway to install the new 30-amp breaker, tighten all the breaker screws. Surprisingly, they can loosen up over time.
   / Maytag (dryer) repair question.... works but no heat #36
An ounce of prevention. Good advice.
We have an infamous code inspector in the area who is known for checking screws with a torque wrench for tightness. Perhaps a bit over the top...
All the best,
Peter
   / Maytag (dryer) repair question.... works but no heat #37
I think he's working in the best interest of the homeowner. I've found screws slack on old breakers when I went looking for the cause of erratic lighting. Fixing that may have averted an eventual fire.
His inspections might be a nuisance, but worthwhile.
   / Maytag (dryer) repair question.... works but no heat #38
They do loosen up sometimes
   / Maytag (dryer) repair question.... works but no heat #39
I definitely agree that screws loosen up over time. I check them whenever I am at the panel.
All the best,
Peter
   / Maytag (dryer) repair question.... works but no heat #40
I found two problems when I investigated how two 1500w heaters killed a 100 amp panel master breaker at the sub-panel in the barn.
First, the underground cable over to the cabin had a splice before it went underground that consisted of a u-shaped connector where the 'saddle' had been slipped on to the two threaded ends of the U, upside down. So torquing down the nuts didn't force the wires together well. It had apparently been like that since the wire was run in the 1960's.
And second, that 100 amp main panel breaker had apparently tripped only one leg which made it burn up inside. Reading about Federal Pacific breakers, this is the principal reason they are no longer sold. But additionally, the heavy cable into that main breaker was sloppy loose, corroded, scorched. It's surprising any power went through it.
I installed a NOS main breaker, and will check all the screws occasionally.
2015 FORD-750 XL SUPER DUTY DUMP TRUCK (A51406)
2015 FORD-750 XL...
2019 Isuzu NRR Roll Off Truck, VIN # JALE5W169K7901549 (A51572)
2019 Isuzu NRR...
2019 Honda CRF1000L Motorcycle, VIN # JH2SD0409KK300478 (A51573)
2019 Honda...
2018 Toro Workman GTX Electric Utility Cart (A51691)
2018 Toro Workman...
New/Unused CFG Industrial MX15 RX Mini Excavator (A51573)
New/Unused CFG...
UNUSED JCT HYD TRENCHER (A51248)
UNUSED JCT HYD...
