Work light for M-F Compacts & Subcompacts
   / Work light for M-F Compacts & Subcompacts
only had this one for one season, I do have block heater and battery maintainer. maintainer is really the most critical.
I wired (fused) direct off battery to 2 switches I mounted in left plastic wraparound piece so they would not get hit on accident but are easily reachable. one switch powers the 19" led facing fwd, other powers the 4 4inch lights which 2 face rear and 2 face onto my 3pt.
19 inch and the 2 facing 3pt are mounted to top of rops with a 4x4 spacer (I am not a tlb so my rops sits lower) to prevent head blocking light.
2 rear facing are hung right off the lower side of the blinker light guards. my gc2400 has guards welded to rops.
yeah I did have to drill rops, made informed decision on it but that method is not for everyone.
Thank You for your reply! I did notice the pictures from a earlier post , But I couldn't see how the where mounted because it was to dark ! But they where putting out some excellent light & thanks for the info on the install.
   / Work light for M-F Compacts & Subcompacts #32
I just looked for sales, overstock etc. and bought those lights/light bars. If not too picky can always get something under $20. If you can do the wiring, but wire, soldering gun, cheap heat gun and shrink tubing (and put a fuse in line). Maybe a switch or two.
Buy over time and you'll be ready for next year.
   / Work light for M-F Compacts & Subcompacts #33
MF1532 will have pics later of rev/pto lights (was daytime when finished) but 80$ for lights before tax.
fused power run from battery to 2 switches in right rear fender then one switch runs main fwd light and other runs the rev/pto lights. slack built in to allow tilting ROPS backwards as needed. 14g marine wiring used, sadly nobody locally has black coated marine wire.
fwd light only on
fwd light only on
Looks nice & those are nice Massey-Ferguson's You got there!
   / Work light for M-F Compacts & Subcompacts #35
the 2400 is mine the 1532 is neighbors which I use often.
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2011 KENWORTH T800 KILL TRUCK & TRAILER (A53843)
2011 KENWORTH T800...
2019 CATERPILLAR D6T LGP HI TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2007 FORD F-750XL SUPER DUTY DUMP TRUCK (A51243)
2007 FORD F-750XL...
2018 CHEVROLET SONIC (A53843)
2018 CHEVROLET...
2022 CATERPILLAR 306CR EXCAVATOR (A51406)
2022 CATERPILLAR...
