John Deere 4310 electrical issue - I think....Please help if you can
   / John Deere 4310 electrical issue - I think....Please help if you can #12
Thank you. Will the turn signal relays be in the spots you listed even with a rear PTO only?
Yes. The slots for mid PTO relays will just be empty.
WARNING: NEVER PUT A FUSE IN THE #12 SLOT!!!!!!
   / John Deere 4310 electrical issue - I think....Please help if you can #13
I had intermittent stopping issues with my 4410. It'll be the same wiring harness if you have ehydro like I do. Eventually I discovered the problem when I needed to repair a broken wire in the seat switch harness.
Thread is here: By pass of seat safety switch - pro's & con's
   / John Deere 4310 electrical issue - I think....Please help if you can #14
I don't know if the problem could be a relay issue. I'm thinking it is an easy first step to try.
The description of it running 5 minutes before blowing the fuse sounds like something warming up before it shorts.
I think that it must be in the PTO circuit since it only happens when mowing.
Looking forward to the eventual fix and report.
Thank you so much. I have a lot to try - I may end up taking it into the shop if I can't trace the issue.
Does anyone know which slot the PTO relay is in? I found the starter relay (3rd down on the far left) not sure what any of the other ones are. This will really help if someone has a diagram of the relays.
i found it!
Yes just when I mow
Do you happen to know what F5 works? I am going to try to trace it back from there if the PTO/Turn signal swap doesn't work. Thanks! You have been a huge help!
   / John Deere 4310 electrical issue - I think....Please help if you can #19
Refer to post #3
2019 CATERPILLAR D6T LGP HI-TRACK CRAWLER DOZER (A51246)
2019 CATERPILLAR...
2004 Ford F-250 4x4 Service Truck with Liftgate (A55788)
2004 Ford F-250...
UNUSED SDLANCH SDLL30 STAND ON SKID STEER (A54756)
UNUSED SDLANCH...
2016 Ford F-450 4x4 Ambulance, VIN # 1FDUF4HT3GEC45874 (A54865)
2016 Ford F-450...
CAT 416B (A47477)
CAT 416B (A47477)
