John Deere 4310 electrical issue - I think....Please help if you can
   / John Deere 4310 electrical issue - I think....Please help if you can #12
Thank you. Will the turn signal relays be in the spots you listed even with a rear PTO only?
Yes. The slots for mid PTO relays will just be empty.
WARNING: NEVER PUT A FUSE IN THE #12 SLOT!!!!!!
   / John Deere 4310 electrical issue - I think....Please help if you can #13
I had intermittent stopping issues with my 4410. It'll be the same wiring harness if you have ehydro like I do. Eventually I discovered the problem when I needed to repair a broken wire in the seat switch harness.
Thread is here: By pass of seat safety switch - pro's & con's
   / John Deere 4310 electrical issue - I think....Please help if you can #14
I don't know if the problem could be a relay issue. I'm thinking it is an easy first step to try.
The description of it running 5 minutes before blowing the fuse sounds like something warming up before it shorts.
I think that it must be in the PTO circuit since it only happens when mowing.
Looking forward to the eventual fix and report.
Thank you so much. I have a lot to try - I may end up taking it into the shop if I can't trace the issue.
Does anyone know which slot the PTO relay is in? I found the starter relay (3rd down on the far left) not sure what any of the other ones are. This will really help if someone has a diagram of the relays.
i found it!
Yes just when I mow
Do you happen to know what F5 works? I am going to try to trace it back from there if the PTO/Turn signal swap doesn't work. Thanks! You have been a huge help!
   / John Deere 4310 electrical issue - I think....Please help if you can #19
Refer to post #3
2015 KUBOTA 1140CPX RTV (A51406)
2015 KUBOTA...
UNUSED RAYTREE RMPP680 HYD POST POUNDER (A54757)
UNUSED RAYTREE...
2012 VOLVO A40F 6X6 OFF ROAD DUMP TRUCK (A51246)
2012 VOLVO A40F...
2017 FORD F550 XL BUCKET TRUCK (A51406)
2017 FORD F550 XL...
2025 Wolverine ADB-13-1218R Auger Skid Steer Attachment with Bits (A52378)
2025 Wolverine...
UNUSED EINGP F10 - 10' WROUGHT IRON SITE FENCE (A54757)
UNUSED EINGP F10 -...
