Amazon.com: Tool Aid SG 25100 Short Tester : Automotive
Buy Tool Aid SG 25100 Short Tester: Multimeters & Analyzers - Amazon.com ✓ FREE DELIVERY possible on eligible purchases
www.amazon.com
Yes. The slots for mid PTO relays will just be empty.Thank you. Will the turn signal relays be in the spots you listed even with a rear PTO only?
i found it!Does anyone know which slot the PTO relay is in? I found the starter relay (3rd down on the far left) not sure what any of the other ones are. This will really help if someone has a diagram of the relays.
Do you happen to know what F5 works? I am going to try to trace it back from there if the PTO/Turn signal swap doesn't work. Thanks! You have been a huge help!Yes just when I mow
Refer to post #3Do you happen to know what F5 works? I am going to try to trace it back from there if the PTO/Turn signal swap doesn't work. Thanks! You have been a huge help!
Got it! Thank youRefer to post #3
