Need tool to put tubing on nipple
   / Need tool to put tubing on nipple #11
How about a blow dryer or heat gun to warm the tubing?
If you got it over three barbs, I would be inclined to put a hose clamp on it and call it done for something that isn't under high pressure and not in continuous use. Just me; I try to pick my battles.
All the best,
Peter
All the best,
Peter
I only got it over one of the three. and it held on the 40 psi sprayer. Until the whole thing quit.
RSKY
   / Need tool to put tubing on nipple #14
The mechanics at a factory I worked at had a tool they used to put rubber hose/tubing on a nipple. It looked like a set of pliers with clamps on the jaws. I needed one today to repair a leak on a 12-volt sprayer. Worked on it an hour and finally got hose on to where I could clamp it. Sprayed 1/8 of what I intended and pump quit. AARRRGGGGHHHHH......
I need one of these once every five years but I would have paid $50+ for it today. Cannot find one online and I know I just don't have the right name in the search.
Thanks.
RSKY
   / Need tool to put tubing on nipple #15
Depending on the size of the hose, I use a pair of needle nose pliers inserted into the hose and spread the handles to streatch the hose and then quickly slid on the fitting.
   / Need tool to put tubing on nipple #16
Could they have been using some version a PEX expander?
Available for 3/8" tubing and up, but designed to expand the collar around the tub, not the tubing itself.
or this copper tubing expander? Copper Pipe Tube Expander Hand Expanding Tool Universal Hand Refrigeration Tools Copper Pipe Swaging Tool Tube Expander 1/4-inch 5/16-inch 3/8-inch 1/2-inch 5/8-inch 3/4-inch 7/8-inch - - Amazon.com
All the best,
Peter
   / Need tool to put tubing on nipple #17
Like the stranger told her husband - "your wife ran off with the plumber to get her nipples rethreaded".
   / Need tool to put tubing on nipple #18
i use a heat gun to get tubes pliable. this is a variable temp one, I just got it, has a high and low as well. works pretty good, and will melt your skin off if you need it too. also comes with attachments to melt heat shrink etc.
Heat Gun
   / Need tool to put tubing on nipple #19
A little RTV silicone on the nipple will lubricate the assembly process.
   / Need tool to put tubing on nipple #20
KBH 25 TON TENDER (A56438)
KBH 25 TON TENDER...
2007 Ingersoll Rand G240 240kVA 3-Phase Towable Diesel Generator (A59228)
2007 Ingersoll...
200 Gallon Tank (A57148)
200 Gallon Tank...
2001 JOHN DEERE 310SG BACKHOE (A60429)
2001 JOHN DEERE...
2024 CATERPILLAR 255 SKID STEER (A60429)
2024 CATERPILLAR...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A60460)
2019 Ford F-150...
