Need tool to put tubing on nipple
   / Need tool to put tubing on nipple #1
RSKY
Elite Member
Kentucky, West of the Lakes, South of Possum Trot.
Kioti CK20S
The mechanics at a factory I worked at had a tool they used to put rubber hose/tubing on a nipple. It looked like a set of pliers with clamps on the jaws. I needed one today to repair a leak on a 12-volt sprayer. Worked on it an hour and finally got hose on to where I could clamp it. Sprayed 1/8 of what I intended and pump quit. AARRRGGGGHHHHH......
I need one of these once every five years but I would have paid $50+ for it today. Cannot find one online and I know I just don't have the right name in the search.
Thanks.
RSKY
   / Need tool to put tubing on nipple #2
Are you talking about Hose Grip Pliers?
No, had my hopes up but those are not the tool. It was like two of those attached together and he would lock one on the nipple and grip the hose with the other and squeeze the handles together to force the tubing straight onto the nipple. Bad explanation I know but that is the best I can come up with.
You might be shocked at what came up on one of the Google searches with the different wording I used.
RSKY
This is close to what I am looking for but it is for only one type of fitting. It is a "push on tool". Now maybe I can find one and end this frustrating search.
   / Need tool to put tubing on nipple #5
Cant you just heat hose and easily slip it over barb nipple?
   / Need tool to put tubing on nipple #7
I tried that. Got a pan of water boiling then poured into a plastic cup (hose had Roundup in it) and soaked the hose for about five minutes. That is how I managed to get it over the first of three barbs.
RSKY
That tool set is over $300. Not what I'm going to pay to repair a sprayer that costs $60 to replace. And I would only need it once every 5-10 years. Looking for something cheaper. Maybe a Harbor Freight one use plastic Chinese special.
RSKY
   / Need tool to put tubing on nipple #10
As long as it won't cause a contamination problem, try a little brake fluid. It works wonders for me.
   / Need tool to put tubing on nipple #11
How about a blow dryer or heat gun to warm the tubing?
If you got it over three barbs, I would be inclined to put a hose clamp on it and call it done for something that isn't under high pressure and not in continuous use. Just me; I try to pick my battles.
All the best,
Peter
All the best,
Peter
I only got it over one of the three. and it held on the 40 psi sprayer. Until the whole thing quit.
RSKY
   / Need tool to put tubing on nipple #14
Thanks.
RSKY
   / Need tool to put tubing on nipple #15
Depending on the size of the hose, I use a pair of needle nose pliers inserted into the hose and spread the handles to streatch the hose and then quickly slid on the fitting.
   / Need tool to put tubing on nipple #16
   / Need tool to put tubing on nipple #17
Like the stranger told her husband - "your wife ran off with the plumber to get her nipples rethreaded".
   / Need tool to put tubing on nipple #18
i use a heat gun to get tubes pliable. this is a variable temp one, I just got it, has a high and low as well. works pretty good, and will melt your skin off if you need it too. also comes with attachments to melt heat shrink etc.
Heat Gun
   / Need tool to put tubing on nipple #19
A little RTV silicone on the nipple will lubricate the assembly process.
   / Need tool to put tubing on nipple #20
2008 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2008 INTERNATIONAL...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2014 HAMM H11IX PADFOOT ROLLER (A60429)
2014 HAMM H11IX...
2019 Ram 3500 HD (A56435)
2019 Ram 3500 HD...
UNUSED SDLANCH 20'X20' HIGH END CARPORT (A60432)
UNUSED SDLANCH...
