how deep can I run a subsoiler (for running pipe) with ck2610
   / how deep can I run a subsoiler (for running pipe) with ck2610 #1
orangetree
Gold Member
central idaho
kioti ck2610
hoping to get my water line run to my wellhead before the ground freezes more than an inch or three ... I have a ck2610 on its way, with backhoe and FEL (so ~~4000lbs), industrial tire tread. Its arriving 1st of November, so in my area it's be close, temperature wise, for the days to fully melt the ground.
soil is ~medium; somewhat sandy, but with enough clay content to harden up quite a bit (and until i have these pipes laid ... i won't have the well water to soften it up; chicken -> meet egg).
I need to get the water pipe to close to 36" (more would be great). My tractor is obviously on the smaller end. I can take multiple passes (only have a few hundred feet to lay.
How deep should I bank on going; in particular will i be able to use the full depth of a 36" blade, with the (albeit small) added drag of the pipe laying bracket? Is a longer subsoiler available / any chance of going deeper with my weight/traction?
Thanks!
   / how deep can I run a subsoiler (for running pipe) with ck2610 #4
you need to trench that deep. subsoil pulling pipe is for stuff more like 6 to 12 inches deep.
anything deeper and you need a vibratory plow
36 hp, weights about what your tractor weighs and vibrates, and has a max depth of 24 inches in good soil. around here a pro-sneak is lucky to be able to reach 18 inches.
Rent a trencher.
yep, this is an option; although its a bit of a pain, and I plan on buying the subsoiler anyway as next year i'll be running irrigation pipe, as well as a bunch of UF.
I've never used a subsoiler, and haven't done much of anything since ~20 years ago on my dad's tractor... so hoping for advice on how deep i'll actually be able to use this (very slick & easy if it works) method.
good info, if that's even partically accurate (I am sure it is), there is absolutely no way this will work. Trencher it will probably be :)
   / how deep can I run a subsoiler (for running pipe) with ck2610 #7
Look in your used listings, three point and hydraulic one come up sometimes, and usually really cheap as they are common one-time use implements.
A three point pto one came up here about 3 weeks ago for $500.
Subsoilers I typically associate with breaking ground not really for trenching. However there is a pipe layer variant that you do both at the same time.
   / how deep can I run a subsoiler (for running pipe) with ck2610 #8
The backhoe would do it but not likely to dig a trench that deep with that size tractor and a sub soiler.
   / how deep can I run a subsoiler (for running pipe) with ck2610 #9
This work?
2015 International DuraStar 4300 Crew Cab Mason Dump Truck (A48081)
2015 International...
2008 Chevrolet Colorado Ext. Cab 4x4 Pickup Truck (A48081)
2008 Chevrolet...
Mk Diamond MK-101 Wet Tile Saw (A49461)
Mk Diamond MK-101...
(INOP) VOLVO L110H WHEEL LOADER (A50459)
(INOP) VOLVO L110H...
2021 Delta Redirective Crash Cushion 75000 (A48081)
2021 Delta...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50774)
UPDATED INTERNET...
