5030
Rest in Peace
- Joined
- Feb 21, 2003
- Messages
- 28,967
- Location
- SE Michigan in the middle of nowhere
- Tractor
- Kubota M9000 HDCC3 M9000 HDC
Lets just say that I started out gas welding using metal coat hangers for filler rod. One thing I will say about starting out with gas welding is it's a very nice precursor to TIG because it teaches you 2 handed manipulation which is absolutely necessary with TIG. Only difference with TIG is the filler rod must be kept in the gas envelope at all times. I went from gas to TIG and had very little issue. While I use pulsed MIG today mostly, MIG is limited in what you can weld while with TIG (and the correct filler rod) you can weld anything that conducts electricity.
Some of the stuff I stuck together with coat hangers is still being used today.
