Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #19,061
Check and see
Still original Chinese tires so metric, but...
160 KPa = 23psi front
120 KPa = 17.5psi rear
I pumped them up before use because they were low from sitting.
That trailer was plain 'ol heavy. It was chucking the truck around getting it here.
Back roads. Took it easy.
Check and see what sidewall says for pressure. I had the same problem on my tractor till I did some research and jacked pressure on my fronts way up from book. Works SO much better now.
   / Tractors and wood! Show your pics #19,062
Check and see
That is from the sidewall. (Turf tires BTW).
   / Tractors and wood! Show your pics #19,063
Out doing some winching
   / Tractors and wood! Show your pics #19,064
Some more
   / Tractors and wood! Show your pics #19,066
Nice, is that a clean up project, or out gathering firewood or both?
   / Tractors and wood! Show your pics #19,068
Both, thinking to make the view from the main road a little nicer.
   / Tractors and wood! Show your pics #19,069
The big round thing.. is that a stack of something or a large pipe with a lid on it?
Remains of a cable drum, both high voltage cables and fiber goes down in the water, and for some reason this was not cleaned up.
2018 Caterpillar D5K LGP Crawler Tractor Dozer (A55787)
2018 Caterpillar...
Eager Beaver SRH150 Roller (A50775)
Eager Beaver...
John Deere 73 Inch Materials Bucket - Needs Carrier (A55218)
John Deere 73 Inch...
Sterling AT (A55301)
UNUSED 200 AMP 13' JUMPER CABLES (A54756)
UNUSED 200 AMP 13'...
2016 John Deere Gator 825i 4x4 Utility Cart (A55787)
2016 John Deere...
