SAE 30 or 10W-30 for older IH FARMALL
   / SAE 30 or 10W-30 for older IH FARMALL #1
superstevek1
Thurman, NY
None looking
Recently acquired older 1972 IH Farmall 140, manual states SAE 30 oil ok to use 10W-30 or 10W-40 or stick with SAE 30 or does it eve matter? Thank you!
   / SAE 30 or 10W-30 for older IH FARMALL #3
I agree with Rick.
   / SAE 30 or 10W-30 for older IH FARMALL #4
Personally, I’m curious why you both recommend 15w-40 for a 20 hp gas tractor? I’m not saying that recommendation is right or wrong, just wondering about the why.
   / SAE 30 or 10W-30 for older IH FARMALL #5
Modern 10w30 oils do not have the zinc needed for old engines with flat tappets. Most cam companies recommend a 15w-40 diesel oil for the higher zinc content.
   / SAE 30 or 10W-30 for older IH FARMALL #7
Those who are concerned about zinc in something like this should consider buying outdoor power equipment oil. I'm no expert on your tractor, but I would think a multi grade would be better for cold weather.
   / SAE 30 or 10W-30 for older IH FARMALL #8
OPE oils are typically formulated for air cooled engines operating at higher temperatures and carry a higher price point than a generic C rated 15w40 oil.
But if it trips your trigger, that's fine.
Like I posted, I would use 15w-40. Whatever you guys use is fine with me.
   / SAE 30 or 10W-30 for older IH FARMALL #9
This is a copy and paste "SAE 30 and 10W30 aren’t the same. SAE 30 is an oil that has a viscosity of 30 at overly high temperatures. The 10W30, on the other hand, has a grade 10 viscosity at low temperatures and grade 30 viscosity when the temperature is high. "
   / SAE 30 or 10W-30 for older IH FARMALL #10
All my older gasoline engines get M1 15w-50. The added zinc, as stated above is necessary for flat tappet lubrication.
(1) 12ft Tarter Gate (A51573)
(1) 12ft Tarter...
REYNOLDS 100 - 8 YARD PULL TYPE SCRAPER PAN WITH DRAWBAR (A52748)
REYNOLDS 100 - 8...
2011 Cadillac SRX Luxury SUV (A50324)
2011 Cadillac SRX...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
Short Flat Bed (A50121)
Short Flat Bed...
10X12 PUMP (A52472)
10X12 PUMP (A52472)
