SAE 30 or 10W-30 for older IH FARMALL
   / SAE 30 or 10W-30 for older IH FARMALL #1
superstevek1
Thurman, NY
None looking
Recently acquired older 1972 IH Farmall 140, manual states SAE 30 oil ok to use 10W-30 or 10W-40 or stick with SAE 30 or does it eve matter? Thank you!
   / SAE 30 or 10W-30 for older IH FARMALL #3
I agree with Rick.
   / SAE 30 or 10W-30 for older IH FARMALL #4
Personally, I’m curious why you both recommend 15w-40 for a 20 hp gas tractor? I’m not saying that recommendation is right or wrong, just wondering about the why.
   / SAE 30 or 10W-30 for older IH FARMALL #5
Modern 10w30 oils do not have the zinc needed for old engines with flat tappets. Most cam companies recommend a 15w-40 diesel oil for the higher zinc content.
   / SAE 30 or 10W-30 for older IH FARMALL #7
Those who are concerned about zinc in something like this should consider buying outdoor power equipment oil. I'm no expert on your tractor, but I would think a multi grade would be better for cold weather.
   / SAE 30 or 10W-30 for older IH FARMALL #8
OPE oils are typically formulated for air cooled engines operating at higher temperatures and carry a higher price point than a generic C rated 15w40 oil.
But if it trips your trigger, that's fine.
Like I posted, I would use 15w-40. Whatever you guys use is fine with me.
   / SAE 30 or 10W-30 for older IH FARMALL #9
This is a copy and paste "SAE 30 and 10W30 aren’t the same. SAE 30 is an oil that has a viscosity of 30 at overly high temperatures. The 10W30, on the other hand, has a grade 10 viscosity at low temperatures and grade 30 viscosity when the temperature is high. "
   / SAE 30 or 10W-30 for older IH FARMALL #10
All my older gasoline engines get M1 15w-50. The added zinc, as stated above is necessary for flat tappet lubrication.
Parker 4000 Gravity Wagon (A50774)
Parker 4000...
3pt Disc Harrow (A50121)
3pt Disc Harrow...
2013 Nissan Sentra Sedan (A50324)
2013 Nissan Sentra...
Case-IH 160 Puma (A50120)
Case-IH 160 Puma...
2000 John Deere 7810 Tractor W/Loader (RIDE AND DRIVE) (A50774)
2000 John Deere...
Pallet of PTO Shafts & Hydraulic Cylinders (A50121)
Pallet of PTO...
