SAE 30 or 10W-30 for older IH FARMALL
   / SAE 30 or 10W-30 for older IH FARMALL #1
superstevek1
Thurman, NY
None looking
Recently acquired older 1972 IH Farmall 140, manual states SAE 30 oil ok to use 10W-30 or 10W-40 or stick with SAE 30 or does it eve matter? Thank you!
   / SAE 30 or 10W-30 for older IH FARMALL #3
I agree with Rick.
   / SAE 30 or 10W-30 for older IH FARMALL #4
Personally, I’m curious why you both recommend 15w-40 for a 20 hp gas tractor? I’m not saying that recommendation is right or wrong, just wondering about the why.
   / SAE 30 or 10W-30 for older IH FARMALL #5
Modern 10w30 oils do not have the zinc needed for old engines with flat tappets. Most cam companies recommend a 15w-40 diesel oil for the higher zinc content.
   / SAE 30 or 10W-30 for older IH FARMALL #7
Those who are concerned about zinc in something like this should consider buying outdoor power equipment oil. I'm no expert on your tractor, but I would think a multi grade would be better for cold weather.
   / SAE 30 or 10W-30 for older IH FARMALL #8
OPE oils are typically formulated for air cooled engines operating at higher temperatures and carry a higher price point than a generic C rated 15w40 oil.
But if it trips your trigger, that's fine.
Like I posted, I would use 15w-40. Whatever you guys use is fine with me.
   / SAE 30 or 10W-30 for older IH FARMALL #9
This is a copy and paste "SAE 30 and 10W30 aren’t the same. SAE 30 is an oil that has a viscosity of 30 at overly high temperatures. The 10W30, on the other hand, has a grade 10 viscosity at low temperatures and grade 30 viscosity when the temperature is high. "
   / SAE 30 or 10W-30 for older IH FARMALL #10
All my older gasoline engines get M1 15w-50. The added zinc, as stated above is necessary for flat tappet lubrication.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A51691)
2025 Kivel 48in...
2021 Doyle 8 Ton Trailer Tender (A52748)
2021 Doyle 8 Ton...
2019 Ford F-550 Service Truck, VIN # 1FDUF5HY1KEF71327 (A51572)
2019 Ford F-550...
2-Row Peanut Inverter (Chain Drive, PTO, 3-Point Hitch) (A52748)
2-Row Peanut...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2007 FORD F-450 SUPER DUTY (A52472)
2007 FORD F-450...
