SAE 30 or 10W-30 for older IH FARMALL
   / SAE 30 or 10W-30 for older IH FARMALL #11
Recently acquired older 1972 IH Farmall 140, manual states SAE 30 oil ok to use 10W-30 or 10W-40 or stick with SAE 30 or does it eve matter? Thank you!
I'd use a 0w, 5w or 10w30 oil in it. They weren't around when the manual was written.
   / SAE 30 or 10W-30 for older IH FARMALL #12
Gotta love oil and additive threads! OPE oils are just fine to be used in liquid cooled engines and are specified to do so. If you want zinc.... Straight SAE 30 has an advantage with high heat more so than a multi grade which makes it desirable in some applications.
   / SAE 30 or 10W-30 for older IH FARMALL #13
I would not recommend 15w-40 if it's a small gas engine, I would use 10w-30 or even 10w-40 if it were mine.
   / SAE 30 or 10W-30 for older IH FARMALL #14
Who said OPE oils were not appropriate?
How much heat are you going to make with a 65 year old water cooled gas engine running 1650 RPM cranking out 25 hp from 152 cu. in?
   / SAE 30 or 10W-30 for older IH FARMALL #15
   / SAE 30 or 10W-30 for older IH FARMALL #16
Dunno who said that they weren't appropriate. My comment was in reference to a couple of points brought up in the thread: 1) The zinc content making them more appropriate for flat tappet engines 2) Regarding some differences between 10W30 VS SAE 30 in certain applications. I wouldn't think this little guy would build much heat internally either. But then again, I dunno. That was info from Briggs and I've seen referenced with other air cooled engine manufacturers at times. Just an interesting point.
   / SAE 30 or 10W-30 for older IH FARMALL #18
Never do what the manufacturer recommends ! 😲 Oil threads get pretty interesting
   / SAE 30 or 10W-30 for older IH FARMALL #19
No multi grade will always be better.
   / SAE 30 or 10W-30 for older IH FARMALL #20
I wouldn't use 15w40 for even a dog engine. Too heavy unless a diesel locomotive or ship engine.
AUCTION STARTS HERE @ 9AM (A51406)
AUCTION STARTS...
2018 RoGator 1100C (A52748)
2018 RoGator 1100C...
Grundfos Centrifugal Pump (A50121)
Grundfos...
New Wolverine Skid Steer 3pt Hitch Quick Connect (A53002)
New Wolverine Skid...
2009 Hino 268 Progress VTA72 1500 Gallon Vacuum Truck (A51692)
2009 Hino 268...
2016 Ford F-150 Crew Cab Pickup Truck (A50323)
2016 Ford F-150...
