Mixing used oil with diesel in the tractor.
   / Mixing used oil with diesel in the tractor. #41
Anyone mixing used oil in with their diesel to cut the cost? I have old hydraulic and motor oil that I can filter and maybe mix in a quart per five gallons of diesel. We went to $6.40 a gallon today and if I project out the increases to winter plowing season, it looks like I might be shoveling this year.
I've ran half or more for decades.
   / Mixing used oil with diesel in the tractor. #42
The mechanics shop at the local Kubota dealership has a waste oil furnace. They get thousands of gallons every year. JMHO - you would have to be a pretty big operation to see any financial benefit from a waste oil furnace system.
I use less than 50 gallons of off-road diesel per year. Adding waste petroleum product to my diesel fuel stream simply wouldn't save that much money. Besides - cost to repair could instantly displace any savings.
   / Mixing used oil with diesel in the tractor. #43
Speaking of which.. Death Valley yesterday:
   / Mixing used oil with diesel in the tractor. #44
Midniteoyl. Not a pleasant sight for those who are or plan on doing some traveling.
   / Mixing used oil with diesel in the tractor. #45
A neighbor has an older model Dodge 1 ton diesel truck and he has been going to restaurants around here for the last 20 years and getting their used cooking oil, filtering it and mixing it with diesel, claims he has never had a problem.
   / Mixing used oil with diesel in the tractor. #46
What is the injection setup in your Kubota? Is it indirect injection? If it is you would probably be ok running used oil if filtered well. I also know someone who runs used cooking oil in older 7.3 Powerstrokes, he just filters it. He said he did used motor oil for a while but said it was too messy.
Would I burn used oil? Not unless I used a lot of diesel. I burn less than a 100 gallons a year so it’s just not worth it.
   / Mixing used oil with diesel in the tractor. #47
Price injectors and injector pump, dirty oil will cost more...
6000 hours on one M9 and 4000 on the other, always using drain oil mixed with the diesel fuel, never been an issue. In fact both have been in for an overhead adjustment and injector spray test, the 6K one last year the 4K one this spring. Both patterns are fine, pintles are fine, replaced nothing. Valves were out that far either. Steady diet of Rotella T6 5-40 with Archoil friction modifier additive in every oil change.
Your comment is baseless and obviously based on what you read somewhere, not actual practice.
I don't ever pre filter the drain oil either. Comes out of the oil pan into a clean catch container and into a clean 5 gallon plastic tote and from there, into the fuel tank and I let my Kubota spin on fuel filter catch anything of interest. I change my fuel filters, every oil change, never had issue one.
My powerstroke Diesel pickup gets the same deal. Been doing it since new in 97.
Diesels, in general will run fine on a lot of 'fuels' other than diesel actually.
Don't much care what anyone does, I do what works for me and I've been doing it for a long time with no adverse issues.
   / Mixing used oil with diesel in the tractor. #48
Never an issue with Seafoam keeping things clean. :)
Seafoam original use is for diesel. It keeps the injectors and pump clean. I use it with regular diesel and bio-diesel mixes. Works ever time.
Buy it by the gallon jug and I use their GDI cleaner on my car intakes every oil change too. Cleans the intake tract and the catylitic convertors as well. Good stuff.
   / Mixing used oil with diesel in the tractor. #49
Yes, and my friend was boasting about it as the vehicle started to loose power and slow down, and we had to stop and fill up with diesel fuel to get going again.
2017 John Deere 1025R Tractor - 626 Engine Hours (A56435)
2017 John Deere...
2004 TRAVIS BODY & TRAILER ALUMINUM BELLY DUMP (A58214)
2004 TRAVIS BODY &...
2001 Freightliner MB55 Chassis Bus (A56858)
2001 Freightliner...
Behringer 19 high x 43 wide Metal-Cutting Bandsaw (A59213)
Behringer 19 high...
HYD QUICK ATTACH STUMP GRINDER (A52706)
HYD QUICK ATTACH...
2016 KOMATSU PC360LC-11 EXCAVATOR (A58214)
2016 KOMATSU...
