/ TRACTOR SLUNG PTO SHAFT!!! - PICS. #41
The shaft and bore have to be smooth for the Shear Pin to work.
The Grade 8, Grade 5 designations are for Tensile (pulling strength) NOT Shear strength. I don't know if there is a difference. What is RC? Remote Clutch?
RC is usually "Rotary Cutter" and graded bolt tensile strength is directly related to shear strength as well. There are standards for that stuff but I do not have them handy.
   / TRACTOR SLUNG PTO SHAFT!!! - PICS. #42
Not really. They just need to get rid of that smooth design, put a simple 6 splined shaft on the input of the gearbox and that alone opens a lot of options of PTO shafts, either clutch type or shear bolt type just like I showed on post #4, which is much much easier to use and not an hassle to use at all.
   / TRACTOR SLUNG PTO SHAFT!!! - PICS. #43
True but not many people want to tear into a perfectly good gearbox to replace a fairly expensive input shaft.
   / TRACTOR SLUNG PTO SHAFT!!! - PICS. #44
I meant the implement manufacturers, not the actual owners.
   / TRACTOR SLUNG PTO SHAFT!!! - PICS. #45
   / TRACTOR SLUNG PTO SHAFT!!! - PICS. #46
What is worse than having to replace a shear bolt once in a while? Having to repair the damage when a clutch doesn't slip.
   / TRACTOR SLUNG PTO SHAFT!!! - PICS. #47
Number one...you should know better..how long you been around ptos?..are you a teenager? Lesson learned..idle down when engaging any PTO in..
   / TRACTOR SLUNG PTO SHAFT!!! - PICS. #48
I recently did some thorough maintenance on my woods BB60 mower. I noticed there was no retainer clip in the end of the shaft to keep the pto shaft from coming off in the event of a sheared pin. Looking closely there appeared to have never been one mounted in the groove. Having had one come apart years ago when I still young and had all 9 of my lives, the sight frightened me considerably. After several fruitless attempts to find one locally, i contacted the Woods dealer and had some mailed to me. After seeing these photos, i will routinely check to be sure that clup is there. Thanks for rhe reminder.
   / TRACTOR SLUNG PTO SHAFT!!! - PICS. #49
I think a lot of people treat the slip clutches like a SET-IT-AND -FORGET-IT part, which it is not. Watch some videos or read the instruction book. They require regular checking and adjustment. Be safe everyone.
   / TRACTOR SLUNG PTO SHAFT!!! - PICS. #50
The clutch increases the cost of the implement. My Countryline from Tractor Supply didn't have a clutch. It used a sheer bolt but even it came with a clip in front of the U-joint half. I remember having a hard time getting to it. After the first use and a bag full of bolts, I bought the clutch. It's worth the $100 not to be out in the field replacing sheer bolts all day.
The clutches are available for splined or smooth shaft. I needed smooth so that's what I got. ;)
2019 TEREX PHOENIX 2100 TROMMEL SCREEN (A53426)
2019 TEREX PHOENIX...
2017 FORD F-250 SUPER DUTY (A53843)
2017 FORD F-250...
Ford Tractor (A50120)
UNUSED FUTURE D45 HYD POST DRIVER (A51248)
UNUSED FUTURE D45...
(INOP) FORD 9N TRACTOR (A51247)
(INOP) FORD 9N...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
