Which 3rd Function Kit to buy for Kioti DK6010SE?
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #1
future_vision
Gold Member
New England
DK6010SE HSA
Ok. So I've seen a Kioti made 3rd function kit(DKA144) that looks super easy to install (video below) but I haven't found a dealer that sells it. Seems like most are installing the WR Long branded one. Is the WR Long any better? If so where is the best place to buy it?
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #2
WR long makes a good kit and they are very helpful with any questions on the install. Everything Attachments sells them as well as other places you can find online.
I see that you get a discount too if you buy the kit with a grapple at EA
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #4
I have a WR Long 3rd function kit with my Land Pride grapple. It made a very clean, tight install.
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #5
We sell tons the custom, proven, easy to install 3rd function kits by WR Long.
Free UPS shipping to your home within 1,000 miles of Conover, NC, and not much if you're outside of the zone.
Find details, several videos, and 500+ customer reviews here: WR Long 3rd Function Kit
Travis
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #6
i tried to get the TYM kit for my tractor. It was worth the extra couple. Of hundred to me to get the pre-bent hard lines with factory brackets to secure them, a bracket for the quick connects which bolts cleanly onto the loader crossmember, and the valve itself which bolts clearly onto the factory loader valve with no extra hoses under the tractor.
But, after waiting for fourteen months with it back ordered, I lowered my standards, and got the WRLong kit.
It installed fairly easily, and works. A bit of a hassle figuring out the hose routing, the supplied joystick handle is functional but ugly. The soft lines running up the loader are mentally bothersome to me. And, I will probably buy the flaring tool, some mounts and hydraulic tubing next time I go to one of the “big towns”, and hardline the FEL.
By the time I buy the tooling and materials to hard line the third function, I’ll have spent a bit more for the third function than if I had been able to get the factory kit.
If having soft lines run everywhere, and secured with zip ties, doesn’t bother you: The WRLong set up is a functional, and less expensive option..
If, like me the loose hoses bothers you, and you will need to buy the hardlines, and clean it up: The factory option is a much cleaner install for less total cost.
And with the low output of my hydraulic pump, it turns out I can’t do more than one function at a time without slowing things way down. So, I probably would have been money, and time ahead to install a splitter/diverter valve on the FEL crossmember to run the grapple.
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #7
Keep in mind that many/most "factory" kits do not have hard lines, either.
Travis
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #8
For example, this is a factory Kioti kit. I have heard many displeased with the valve location/hose routing on those..
Travis
Travis
I have to watch it again but I think the guy in the YouTube video I posted swung the hoses upwards and installed the shield upside down. Still needed a cover to protect the top and keep debris from falling in.
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #10
Travis
Sure looks like an easy fix would be simply flip the cover 180 degrees and run the hoses up instead of down. The point of the cover is to protect from stuff coming the ground, like sticks, branches. Not from an hail storm coming from above.
206707 (A58375)
206707 (A58375)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2011 MULTIQUIP LIGHT PLANT/ FUEL TANK TRAILER (A58216)
2011 MULTIQUIP...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
JLG 660SJ (A58214)
JLG 660SJ (A58214)
2021 CATERPILLAR 299D3 SKID STEER (A60429)
2021 CATERPILLAR...
