Which 3rd Function Kit to buy for Kioti DK6010SE?
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #1
future_vision
New England
DK6010SE HSA
Ok. So I've seen a Kioti made 3rd function kit(DKA144) that looks super easy to install (video below) but I haven't found a dealer that sells it. Seems like most are installing the WR Long branded one. Is the WR Long any better? If so where is the best place to buy it?
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #2
WR long makes a good kit and they are very helpful with any questions on the install. Everything Attachments sells them as well as other places you can find online.
I see that you get a discount too if you buy the kit with a grapple at EA
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #4
I have a WR Long 3rd function kit with my Land Pride grapple. It made a very clean, tight install.
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #5
We sell tons the custom, proven, easy to install 3rd function kits by WR Long.
Free UPS shipping to your home within 1,000 miles of Conover, NC, and not much if you're outside of the zone.
Find details, several videos, and 500+ customer reviews here: WR Long 3rd Function Kit
Travis
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #6
i tried to get the TYM kit for my tractor. It was worth the extra couple. Of hundred to me to get the pre-bent hard lines with factory brackets to secure them, a bracket for the quick connects which bolts cleanly onto the loader crossmember, and the valve itself which bolts clearly onto the factory loader valve with no extra hoses under the tractor.
But, after waiting for fourteen months with it back ordered, I lowered my standards, and got the WRLong kit.
It installed fairly easily, and works. A bit of a hassle figuring out the hose routing, the supplied joystick handle is functional but ugly. The soft lines running up the loader are mentally bothersome to me. And, I will probably buy the flaring tool, some mounts and hydraulic tubing next time I go to one of the “big towns”, and hardline the FEL.
By the time I buy the tooling and materials to hard line the third function, I’ll have spent a bit more for the third function than if I had been able to get the factory kit.
If having soft lines run everywhere, and secured with zip ties, doesn’t bother you: The WRLong set up is a functional, and less expensive option..
If, like me the loose hoses bothers you, and you will need to buy the hardlines, and clean it up: The factory option is a much cleaner install for less total cost.
And with the low output of my hydraulic pump, it turns out I can’t do more than one function at a time without slowing things way down. So, I probably would have been money, and time ahead to install a splitter/diverter valve on the FEL crossmember to run the grapple.
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #7
Keep in mind that many/most "factory" kits do not have hard lines, either.
Travis
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #8
For example, this is a factory Kioti kit. I have heard many displeased with the valve location/hose routing on those..
Travis
Travis
I have to watch it again but I think the guy in the YouTube video I posted swung the hoses upwards and installed the shield upside down. Still needed a cover to protect the top and keep debris from falling in.
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #10
Travis
Sure looks like an easy fix would be simply flip the cover 180 degrees and run the hoses up instead of down. The point of the cover is to protect from stuff coming the ground, like sticks, branches. Not from an hail storm coming from above.
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #11
Well - POO. I'll post a pic to show where the dealer installed the WR Long on my tractor. It's attached to the vertical post on the FEL. It's on the inside and up high and safe. For this pic - I'm sitting in the tractor seat - looking forward.
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #12
The OEM 3rd function kit as shown in the picture referenced has the hoses and protection plate mounted upside down. When installed in the correct orientation, the lines come up and immediately out of the way. In addition, the included protection plate is also upside down and once flipped, will protect the connections at the new valve. Kioti dealers have a large margin on the 3rd function kit - so it pays to have a good relationship.
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #13
Different tractor - different mounting methods. The " top protection plate" on mine is the floor plate. All connections are well under this plate. There is also a large metal "box" under the floor plate that protects the connections from anything below and to the side. Here you can see that box. This "box" extends well beyond the hydraulic connections - almost to the center line of the tractor. Sorry - all my resizing and cropping has made this a rather cobby image.
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #14
No offense to the OP, but makes me glad I went with the NX series. Third function kit gets installed into a very secure box under the 'passenger' side step area. I'll end up ripping off other lines before anything on the third function breaks.
Only issue I've had thus far is the dealer not giving the actual wires that run between the loader joystick and the diverter enough slack. Had a break in the 'close' wire that would cause intermittent issues. Attributed it to normal rattling of the tractor on tight wires causing to much stress.
No offense. I'm getting my tractor used for a great deal. If I had my way I would have gotten a new RX63620 or the RX7320 with ROPS and power shuttle but couldn't pass up the deal. They did have some NS6010's ROPS on the lot. Don't know why I never priced those out.
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #16
If you search this forum you will find all of the information you need to install your own from components purchased either online or at a local hydraulics store.
Looking at EA's site they have the WR Long kit but they also list and upgrade
"Upgrade for tractors that use more than 15GPM - $100"
The Kioti DK6010SE has a Total Pump Flow of 16.49 gpm (62.4 L/min). Not sure if this the the gpm they are talking about or the gpm to the attachments or something else?
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #18
You do not need the upgraded one!
Travis
   / Which 3rd Function Kit to buy for Kioti DK6010SE? #19
I'd recommend the Kioti DK 3rd function kit. I just picked one up for my DK4210SE Cab model and it is the same one that you will need. If you watch that video at the beginning of this thread, you will see how easy it is to install and how integrated it is. Shame on the EA guys for purposely posting a pic of an incorrect install with the lines going down. Watch the video as he almost makes that same mistake. When installed properly, the OEM Kioti kit is easily the most integrated/protected kit and IMO has the best (OEM) loader handle with the integrated open/close buttons. I picked up my kit for $864 and I'm sure the dealer was still making a profit.
AUCTION STARTS HERE @ 9AM (A60429)
AUCTION STARTS...
2019 CATERPILLAR D6 HIGH TRACK CRAWLER DOZER (A60429)
2019 CATERPILLAR...
2013 Ford F-250 Pickup Truck (A59230)
2013 Ford F-250...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
2012 BIG TEX PIPE TRAILER (A55745)
2012 BIG TEX PIPE...
