Hay Dude
Super Star Member
- Joined
- Aug 28, 2012
- Messages
- 18,899
- Location
- A Hay Field along the PA/DE border
- Tractor
- Challenger MT655E, Massey Ferguson 7495, Challenger MT535B, Krone 4x4 XC baler, (2) Kubota ZD331’s, 2020 Ram 5500 Cummins 4x4, IH 7500 4x4 dump truck, Kaufman 35’ tandem 19 ton trailer, Deere CX-15, Pottinger Hay mowers
Guess I am human---maybe to human. Filled up the tractor today and then did some spot mowing of CRP. It was dusty off and on. After mowing for about 2 hours, I realized I forgot to screw the cap back on the fuel tank. I am guessing there was close to 5 gallons of diesel that spilled out. The back of the tractor is a mess as the dust and crp residue collected on the spilled fuel. The tractor is still running fine but am wondering what would be the wise thing to do at this point? Should I go ahead and burn most of the fuel before attempting to change the fuel filteror go ahead and change it now and then maybe again after I use the fuel up more? Thoughts!
Yes. for now, the path of least resistance is to keep running it. However, its not advisable to run the tank down real low on fuel ever, if possible. You may have also gotten very little debris in the tank.
I’d just change the fuel filter a few times in the next 100 hours.
If you want to get elaborate about it, pull the line or drain on your tank once it gets low and do a rinse-out.
