YKMT43 tiller oil leaking between bearing and tiller shaft. With pics any ideas
   / YKMT43 tiller oil leaking between bearing and tiller shaft. With pics any ideas #31
I figured it out. I had the chain box overfilled and it was leaking. I also used a shaft to bearing View attachment 759425
seal called FAS LOK 80 that I got at the bearing shop.
Lesson learned about overfilling chainbox for me.
Not too long ago, someone else overfilled the chainbox. We learned the fill line is about 2/3rds up from the bottom.
FAS LOK 80 sound just like Loctite 290 comparing it on-line. Neither are cheap either.
   / YKMT43 tiller oil leaking between bearing and tiller shaft. With pics any ideas #32
They aren't cheap, but when you need them, you need them, and @gt14 clearly needed it.
I have a little cache of various Locktite products for the various uses, and I never begrudge their use because they work so well in their intended uses, and it rarely takes much. Early on I learned the hard way never to use the high strength just because it was there; I think that the label should read "Use for fasteners that you intend to destroy if their removal is ever needed". Doh!
@gt14 I am glad that you got it sorted out.
All the best,
Peter
The compound is very expensive $36 I was shocked
2025 K0608G UNUSED 3-Rail Style Fence (A53117)
2025 K0608G UNUSED...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
Hydrema 912HM Haul Truck (A52384)
Hydrema 912HM Haul...
1472 (A51247)
1472 (A51247)
9 OFFICE CHAIRS (A53843)
9 OFFICE CHAIRS...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
