Front Axle Filler Plug Size (socket to use)
   / Front Axle Filler Plug Size (socket to use) #1
Sooner79
Far North Texas
Branson 2515H
On a 15 series, what size socket is used to remove the front axle fill plug? Thanks.
   / Front Axle Filler Plug Size (socket to use) #2
24 or 27MM but I'll check later today, in an hour or so.
Doesn't Branson include a Branson labeled bag with a bunch of tools and small grease gun with the tractor in the US? Over here they send a nice bag with the manual and a bunch of tools. About the cheapest tools but still handy to have and I keep them in the toolbox with the tractor.
   / Front Axle Filler Plug Size (socket to use) #3
No! But we may get a hat. :ROFLMAO:
   / Front Axle Filler Plug Size (socket to use) #7
I would actually appreciate a Branson hat😁
Brother, I don’t think they have a appropriate hat for where you live. I seem to remember it being so cold there that steel becomes brittle. ;)
I received a couple of Branson caps when I bought mine. They're truckers caps (mesh back)... definitely not the best headwear for Talkeetna.
   / Front Axle Filler Plug Size (socket to use) #8
I finally confirmed what wrench it uses for the front axle dipstick and it's indeed a 27 MM wrench.
Oh and little tip, even though it uses a big wrench, it doesn't need to be crazy tight, just snug. There is an O-ring that does the sealing between the dipstick plug and the casting which tends to get stuck on the casting.
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A59823)
KNOW BEFORE YOU...
LMC 2-Row Planter BYJ-2F  Stainless Steel Fertilizer Boxes, Ground-Driven (A56438)
LMC 2-Row Planter...
2025 Swict 84in Bucket Skid Steer Attachment (A59228)
2025 Swict 84in...
Towable Centrifugal Water Pump (A59228)
Towable...
