Front Axle Filler Plug Size (socket to use)
   / Front Axle Filler Plug Size (socket to use) #1
Sooner79
Far North Texas
Branson 2515H
On a 15 series, what size socket is used to remove the front axle fill plug? Thanks.
   / Front Axle Filler Plug Size (socket to use) #2
24 or 27MM but I'll check later today, in an hour or so.
Doesn't Branson include a Branson labeled bag with a bunch of tools and small grease gun with the tractor in the US? Over here they send a nice bag with the manual and a bunch of tools. About the cheapest tools but still handy to have and I keep them in the toolbox with the tractor.
   / Front Axle Filler Plug Size (socket to use) #3
No! But we may get a hat. :ROFLMAO:
   / Front Axle Filler Plug Size (socket to use) #7
I would actually appreciate a Branson hat😁
Brother, I don’t think they have a appropriate hat for where you live. I seem to remember it being so cold there that steel becomes brittle. ;)
I received a couple of Branson caps when I bought mine. They're truckers caps (mesh back)... definitely not the best headwear for Talkeetna.
   / Front Axle Filler Plug Size (socket to use) #8
I finally confirmed what wrench it uses for the front axle dipstick and it's indeed a 27 MM wrench.
Oh and little tip, even though it uses a big wrench, it doesn't need to be crazy tight, just snug. There is an O-ring that does the sealing between the dipstick plug and the casting which tends to get stuck on the casting.
2025 JMR 36in Bucket Mini Skid Steer Attachment (A59228)
2025 JMR 36in...
2009 Sterling Acterra Altec DM47TR Insulated Digger Derrick Truck (A60460)
2009 Sterling...
2001 International 4000 DT 466E (A60462)
2001 International...
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
2016 Ford Expedition XLT 4WD SUV (A59231)
2016 Ford...
Case Wheels for Combine/Firestone Tires w/ extra rings NO RESERVE (A56438)
Case Wheels for...
