Hydraulic pump TC 29 New Holland
   / Hydraulic pump TC 29 New Holland #1
Aaron29
TC29 New Holland
Need help with hydraulics not working. Is the pump bad or do I have other issues? The hydraulic pump is real noisy when I try to lift and takes a minute to start lifting 3 point hitch.
   / Hydraulic pump TC 29 New Holland #2
Let's start with basic stuff first, it the fluid at the right level? What's the condition of the fluid? Good? Bad? Changed recently? And the hydraulic filter? Has it been changed? Screen cleaned? If has one.
I have check led fluid and changed filter and oil. I was getting a terrible noise when I first started tractor but would get better when warm. Now lift doesn’t work but every once in a while
   / Hydraulic pump TC 29 New Holland #4
What filter and oil did you use? OEM filter and oil?
   / Hydraulic pump TC 29 New Holland #5
Any rubber hoses on the pump inlet line? If yes check these for any signs of cracks. Noisy pump generally indicates pump is being starved of oil or cavitating.
I used a new holland filter with travelers universal hydraulic fluid from tractor supply.
thanks 1 rubber hose From the oil filter to pump could have a small leak.
   / Hydraulic pump TC 29 New Holland #8
I hope at least your machine is gear drive if your useing that fluid. This machine does have wet brakes and possibly a pto wet brake and I wouldnt be useing anything but NH fluid. It's about $90 for 5gal but cheaper than parts.
   / Hydraulic pump TC 29 New Holland #9
TS travelers universal hydraulic fluid usually runs a bit heavier in viscosity that the NH OEM fluid. Works well in warm/hot weather.
   / Hydraulic pump TC 29 New Holland #10
Cheap TSC fluid usually equates to issues down the road. You get what you pay for in life and being cheap usually results in expensive repairs later on. Never purchased any and don't plan on it either.
1987 Ravens 45 ft. T/A Float Trailer (A53117)
1987 Ravens 45 ft...
Galvanized Livestock Gates - (6x Total Gates) (A55218)
Galvanized...
66'' root grapple (A53421)
66'' root grapple...
Freightliner Tender Truck - Adams Tender (A55301)
Freightliner...
2024 CATERPILLAR 255 SKID STEER (A52705)
2024 CATERPILLAR...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
