I used a new holland filter with travelers universal hydraulic fluid from tractor supply.What filter and oil did you use? OEM filter and oil?
thanks 1 rubber hose From the oil filter to pump could have a small leak.Any rubber hoses on the pump inlet line? If yes check these for any signs of cracks. Noisy pump generally indicates pump is being starved of oil or cavitating.
I hope at least your machine is gear drive if your useing that fluid. This machine does have wet brakes and possibly a pto wet brake and I wouldnt be useing anything but NH fluid. It's about $90 for 5gal but cheaper than parts.I used a new holland filter with travelers universal hydraulic fluid from tractor supply.
Hydraulic oil has no standard 3rd party checks like the API for engine oil. In hydraulic oil the manufacturer specs the weight and additives. So anyone can claim its equivalent but theres no one to do the checks and balances.TS travelers universal hydraulic fluid usually runs a bit heavier in viscosity that the NH OEM fluid. Works well in warm/hot weather.
Yes just drained it and looked like pieces of cast metal.Was there any sign of water in the oil? When mine went it did the same thing. Took it to the dealer and he replaced the pump.![]()
