Kubota B3030 RPM needle stuck at max on the dial ...
   / Kubota B3030 RPM needle stuck at max on the dial ... #1
mykubota4x4
Member
Kubota B3030HSDC
Hey Folks
My B3030 RPM needle got stuck at max on dial & never came back down while i tried cold starting in frigid minus 20c, It does run fine & accelerate fine & have been using it that way for over a year now. If anyone had this issue or knew whats the cause would love to get it fixed.
   / Kubota B3030 RPM needle stuck at max on the dial ... #2
I think that’s a cable drive tachometer. The cable is probably broken. It’s not that hard if a repair.
   / Kubota B3030 RPM needle stuck at max on the dial ... #3
I think that if the cable was broken,the tach/hourmeter would read zero.
Is the hourmeter still adding hours?
Perhaps the gauge head needs repair?
Please post back!
Please post back!
The hour meter still works & adds up while running, I doubt if its cable inside.
   / Kubota B3030 RPM needle stuck at max on the dial ... #6
A good whack might help?
Good Luck!
   / Kubota B3030 RPM needle stuck at max on the dial ... #7
AKA “Technical Tap”
   / Kubota B3030 RPM needle stuck at max on the dial ... #8
Perhaps drill a tiny hole in the instrument face.
Think tiny hole for odometer reset button.
Reach inside the gauge with a bent paper clip to persuade the needle back to bottom of scale.
This has worked for me before with an gauge cluster with the tiny hole.
Not sure if the gauge would cloud up after this?
Good Luck!
Good Luck!
Never had that idea of pin hole, may as well try to open the cluster, shouldnt be that hard..i guess.
   / Kubota B3030 RPM needle stuck at max on the dial ... #10
Since you have a cab,the hole should have minimal effect.
Auto dash clusters have few issues with the hole.
Good Luck and post back!
Kubota HB84 Hopper Broom (A53317)
Kubota HB84 Hopper...
2003 IC Corporation 3000IC School Bus (A59230)
2003 IC...
2018 Dodge Ram 3500 (A53317)
2018 Dodge Ram...
iDrive TDS-2010H...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55302)
2000 Kenworth W900...
Champion Vibratory Roller (A60462)
Champion Vibratory...
