New (used) IH 7500 Dump Truck purchase, modification & fix up
/ New (used) IH 7500 Dump Truck purchase, modification & fix up #21
Some of those hoses look like they're for the front wing. What's the small ball valve for on top, any idea
I’d like to sell off the complexity of this system and trade it for the simplicity of a 12’ PTO driven dump.
I don't think you should have much of a problem doing an even trade, especially if the bodies in half decent shape and conveyor works. If you decide to strip it yourself, be sure to take a video of all the hydraulics working, side dump, conveyor, main dump etc for proof to show someone.
I believe its a shut off valve to close off hydraulics to rear, but haven’t had much time to investigate.
/ New (used) IH 7500 Dump Truck purchase, modification & fix up #23
Just out of curiosity what is a live floor salter? Has it got a conveyor type setup in the bottom so you don’t have to raise the box to feed the spinner?
/ New (used) IH 7500 Dump Truck purchase, modification & fix up #24
Dave, that's right, and the chain can feed a mid-mount spinner to put the product in front of the rear tires.
Nice rig Hay Dude!
/ New (used) IH 7500 Dump Truck purchase, modification & fix up #25
After a lot of looking around for a dump truck, I finally found pretty much what was wanted.
Must haves were
1. 4x4 chassis
2. Heavy specs (>35K GVWR)
3. Higher than typical HP/TQ
4. 3 stage engine brakes
5. Automatic trans
6. Single thick frame-not double.
I hit on the first 5, but not 6.
2007 IH 7500 4x4, 41,000 GVWR, HT570 (310/1050) with 3 stage brake, Allison Rugged Duty series, double frame.
Just got here today and didnt have a lot of time to go through it. It has a wing plow frame and a stainless steel dump with a live floor salter system and spinner.
I have no use for the salting equipment and would prefer to sell everything off the truck and install a standard 12’ steel dump box.
Dang, Dude! Nice truck.
Yes, it feeds to the front goes through the open door and drops to the spinner.
/ New (used) IH 7500 Dump Truck purchase, modification & fix up #27
The inside of that body looks to be in good shape as long as the conveyor is not seized up, couple gallons of waste oil sprayed on the chain would work wonders.
Check the side dump hinges also, once they seize up you have a bad job on your hands, a few shots of grease works wonders.
The rubber wiper is partially missing from the headboard too, not a big deal but you'll lose product .
It does drop salt or sand ahead of the rear axle which is good but the bad thing about them is it drops salt over the frame from leakage of the return tray underneath, totally covering the frame in salt.
Depending on how the side dump/reloading cylinders are configured it can be hard on the moveable section as well as the main frame rails of the body. If they're at a really low angle (which some are) it pushes the moveable section and the frame rail apart until it gets high enough to move it up easily. If you get a ham handed operator that tries to reload the conveyor before the product is low it's not good.
Still think it's worth $$$ to trade for a conventional :)
/ New (used) IH 7500 Dump Truck purchase, modification & fix up #28
I went back and looked a see the spinner now, up just behind the front door. I‘ve seen live bottoms before where they feed out the back, usually a long trailer, and they use them for asphalt into the paver.
Your truck dumps sideways also to feed the live bottom?
I’m thinking more & more about selling everything now as a complete set up. Hydraulic pump out front, too.
I just want to be left with a bare chassis a while, restore the frame & paint it, and install simple tough steel bed, replace wheels, fix exhaust manifold gasket and whatever else I can afford and I’m good.
If a used 12’ stainless bed bed came along, that would be amazing. It looks good with the green cab.
The frame is decent. A bit of rust scale on the opposite side of the spinner. Spinner side is actually pretty good. I think they did a good job cleaning off the salt where they thought it’d be worst, but no matter how good a job you do, it still makes a mess.
Got an offer of $11,000 for stainless steel dump, telescopic hoist, hydraulic tank and salt spinner.
I gotta pay to remove. Probably a grand.
End up with $10,000 to put towards new 12’ dump, hoist & PTO
/ New (used) IH 7500 Dump Truck purchase, modification & fix up #31
IMHO I think it's worth than that if the body's in good shape. It all depends how bad you want to get rid of it so I can't fault you one way or 'tother :).
Telescopic cylinder is $1K+, spinner probably close to the same, hydraulic tank $6-700. Body is dependant on shape.
Think they'd go for them removing the body, if you trust them not to hack anything.
What about the cab controls and valve bank, that included too? They'd be no good to you.
/ New (used) IH 7500 Dump Truck purchase, modification & fix up #32
(y)
You think $11,000 is low?
Me and a buddy of mine who inspects & fixes my equipment will probably do it.
My big issue is salt/snow equipment that isn’t sold in the next 2-3 weeks isn’t going to sell until next fall. I want it off now so I can restore the frame, install new wheels and fix it up from the ground up.
Might want to jump on their offer while snow equipment is in demand
/ New (used) IH 7500 Dump Truck purchase, modification & fix up #34
I do but I've been accused of thinking stuff I have is less valuable than I think it is. I have to try and remember also that I'm used to new prices having bought equipment like that the last 5-6 years I was working.
Very good point, a sure thing at $11K or possibility of maybe more heaven knows when.
If you do decide to strip it, remember....no pics or it didn't happen :)........Mike
/ New (used) IH 7500 Dump Truck purchase, modification & fix up #35
I think you should jump on it. The used market is very subjective. Maybe you could get more, but the chances are higher that if you hang onto it, it will be sold as scrap someday. And $10 towards the new body is a good start.
Todays prices on steel and truck parts are absolutely insane because of rampant runaway inflation.
Yeah it’s pretty much now or never to sell plowing/salting equipment.
I will take progress pictures. Will remove body next week, then begin frame restoration. Also will be adding pintle plate, hitch, electric trailer brakes, tail lights and probably glad hands to rear. For some reason the trailer parking brake release valve is missing.
Don’t know for sure when new body will go on.
Need to find some new wheels as the ones on there look like crap.
For some reason the trailer park brake valve was there, but it’s gone now. No glad hands, either.
Has air trailer brakes
HITACHI EX550LC EXCAVATOR (A58214)
HITACHI EX550LC...
2016 John Deer 5075E (A60462)
2016 John Deer...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2016 CATERPILLAR M322F MOBILE EXCAVATOR (A60429)
2016 CATERPILLAR...
2013 Freightliner Forest River 390BH 39ft. Class A Motorhome (A59231)
2013 Freightliner...
2022 NIFTY TM34TE-MK1B TOW BEHIND BOOM LIFT (A60429)
2022 NIFTY...
