/ What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,621
over last 3 days winds been gusting to 30mph and temps today topped out 41.7 so...no hydro stuff done today.
this, MY tractor, only thing left to do. eng oil, fuel filter,grease....all done. just hydro stuff front and rear.
tomorrow still gonna be 40-45 deg but low winds. it will get done then.
one tractor on lawn a lot better than 4 on lawn.
I spy with my little eye...a craftsman dump cart. I got one of them.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,622
Yo D, I hated the pivoting back door on that cart, so I changed it...welded on some channel so that the door just slides off completely:
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,623
View attachment 769725 View attachment 769724
don't have pivot door on this, its slide up and out door. much like you made.
was the largest cart sold in this style back in 2006 or so, its pretty big. smaller carts used the swing door.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,624
hydro done on my GC2400. accidentally put about 1/2 qt too much in it. should be ok, runs fine.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,625
Mine's been slightly overfull by about the same mount for almost 2 years with no ill effects. Was at the bottom of the glass and added, does not take much to go from there to overfull. I can see the level when extend all the FEL cylinders.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,626
yup, plus after I remove bucket a few times level will drop a touch.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,627
The full level for the hydraulic fluid on a GC, is not critical.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,628
if you overfill too much you can create a foaming issue. that ain't good.
1/2 qt....yeah not an issue
last time I serviced MY unit (no garage, level surface hard to find so I actually use levels 2ft and 4ft on tractor normally) I never noticed fill glass had been covered and I ended up adding extra gallon.
disconnect one loader line, connect hose from coupling to bucket. pull loader lever. it comes out pretty fast LOL
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,629
someone buying company 2010 cam superline 6CAM18FT tilt trailer. used GC to move it so truck can hook on fast.
moved the 7x14 enclosed trailer with owners personal items in it to better location. moved his GC1723TLB to better location.
7x14 twin cylinder CAM dump also sold but will be week before picked up, GC will move that too.
his 2019 dodge 2500HD cummins sitting on charger right now, sitting for months messes it up and the preheat takes a LOT of juice.
once he signs docs I take over payments of this.
not gonna get into details but if your bail conditions say don't get near anyone under 18....DON"T ******* DO IT!!!
cause you will lose everything.
   / What have you done with/to your GC Series 2300, 2400, 1700 Tractor TODAY #1,630
twitched some very small poplars (4" diameter) out for neighbor for firewood as well as carried the 16" cut length stuff up to firepit for them. gotta cure for few months still.
oh yeah I also cut them as neighbors saw died.
4 buckets of 16" poplar carried up 300 feet to pit, average 30 logs per bucket.
once it dries will be good.
I hauled from woodline, neigbor cut (using my saw as his died) his kids loaded stuff into my bucket. easy peasy
2006 Columbia Medical Transport Electric Utility Cart (A56859)
2006 Columbia...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A57024)
NEW HOLLAND 706 30...
TUGGER TRAILER (A55745)
TUGGER TRAILER...
2008 JCB 190 ROBOT SKID STEER (A60429)
2008 JCB 190 ROBOT...
BOX BLADE (A58214)
BOX BLADE (A58214)
iDrive TDS-2010H...
