Hit A Road Block With Fittings ?
   / Hit A Road Block With Fittings ? #1
BxB301
Member
Lincoln
Things were going great on my project until it came time to install some 90's on my valve block.
-Can't screw in more than 1.
How the HE Double Hockey-Sticks am I going to make this work?
Valve block ports are #8 SAE, and those are 8 SAE to 8 JIC 90's
Also have long ones for the top - which also cant screw in without hitting the one next to it.
   / Hit A Road Block With Fittings ? #2
   / Hit A Road Block With Fittings ? #3
You may need to ditch those and get some straight SAE #8 to JIC, then have the 90 fitting crimped directly on the hose but I don't think that's common to use over there. Instead you may need to use a male JIC to female JIC 90 fitting.
EDIT: What Brian said! (y)
$22 & $37 each! Yikes.
At least I can get away with the cheap fittings every other hole- I think the local hose guys said he doesn't have any of those. Ill go check before ordering them for him.
thanks for the reply!
   / Hit A Road Block With Fittings ? #5
THIS.
If you don't want to use crimped 90's (I try not to because of "clocking" issues and hose memory), you can use 90* JIC fittings and then straight JIC fittings on your hoses.
Or 45's:
   / Hit A Road Block With Fittings ? #7
In my experience a short and long 90 will NOT work; To get clearance I had to go to a short and a "long long" (from Discount Hydraulics, anyway) - see attached pic ... Steve
   / Hit A Road Block With Fittings ? #8
You might have already crossed this bridge but i was thinking you could thread in the 2 outer ones and get a male to female coupler for the center one so it stands off high enough to clear the others.
   / Hit A Road Block With Fittings ? #9
Use a straight ORB adapter on the ones where the 90's wont work. Then use the 90 JIC fittings that kenny posted in the first link.
I avoid the 90's on the hose itself not only because of memory, but cost. Those 90 hose fittings are more expensive and arent as readily available in a pinch.
   / Hit A Road Block With Fittings ? #10
Could you not use something like this male/female fitting to extend one set of connectors to get clearance... These are only a few bucks each...
   / Hit A Road Block With Fittings ? #11
There are numerous options.
You could see just how many fittings can a person use? :rolleyes:
You can figure out the absolute cheapest way to go as well as finding out what supplier is going to provide each and every piece at the cheapest rate.
Or if your time is worth about anything to you, you can just use the cleanest way of doing what it is that you need to do.
As far as hose memory and clocking of any angled fitting on a hose, after a few thousand hoses provided, I have not had a single issue when there is a straight fitting at the opposite end of the angled fitting.
But I can only speak from my experience. Apparently, others have had issues of some kind?:unsure:
Good luck with however you end up dealing with the issue. (y)
2004 JOHN DEERE 160C LC EXCAVATOR (A59823)
2004 JOHN DEERE...
2020 CATERPILLAR 320 GC EXCAVATOR (A60429)
2020 CATERPILLAR...
Kubota Z232 (A60462)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 Cat 259D3 (A53317)
2021 Cat 259D3...
2016 Chevrolet Sonic LS Hatchback (A56859)
2016 Chevrolet...
