WoodChuckDad
Elite Member
- Joined
- Jul 15, 2015
- Messages
- 2,931
- Location
- Free Union, VA
- Tractor
- Kioti RX7320 Power Shuttle Cab, Komatsu PC130-6
The front ball joint on my tractor is bad. Noticed it yesterday. lots of play. I had a spare because in 2017 the castle nut came off and the assembly got bent.l but I was able to get it back on and fastened with another nut. I cut that nut off today and I am trying to get the assembly loose. The piston for the hydraulic arm and the assembly screw together with the black steel going into the the stainless piece. But I can't get them separated. Thee stainless piece seems to be about 27 mm and the black piece fits a 35 mm wrench. I am working both wrenches underneat with the smaller wrench wedging against the front arm of the tractor. It is standard thread and Iam pushing and hitting the wrench with a small sledge. been at it a while. No luck. should I try heat? is there a danger of damaging the seals of the hydraulic if I do that?
