Ford 1300 fuel filter housing
   / Ford 1300 fuel filter housing #1
Schoochie
Member
Ford
Looking for a fuel filter housing for a Ford 1300 -the nut that holds the filter on is cross threaded
Could I just by pass the original filter housing with a in line filter from the auto parts store-I’ve seen some pics of folks that have done that
   / Ford 1300 fuel filter housing #3
yes you can do that. Do you have any pics? I did change the bowl and filter with no issue from after marker stuff and not OEM and yet have any issues. Below is exactly what I bought. With fuel bowl is easier to bleed the air out than in in-line filter but very much a doable thing. My fuel bowl was old and dry and it cracked when I tried to open it up to change the filter.
Thank you again JC-i do not have any pic’s right now but mine looks similar to yours-where did you purchase that from-I’d like to keep it original as possible-vs-rigging
   / Ford 1300 fuel filter housing #5
I bought it from Kumar brothers at ebay. Just click the link. I actually think I bought two as they had a special pricing then. Take the outer ring that tightens it, clean it off and inspect. may be it is not cross threaded. They are good people to buy parts from if they stock them. This was my original bowl that became so brittle and as soon as I tried to open the retaining threaded ring the plastic bowl cracked.
Oh wow-thank you again for your advice-i normally buy from Amazon-filters ect-I’m kinda new messing around with these older tractors-i was into the trucks and cars for years-kinda changing hobbies 👍
Hey JC -i did replace that original fuel bowl with a aftermarket wix type ( car fuel filter) it works fine-but did have to bleed the air out only twice to get the tractor running-thank you for your knowledge 👍
   / Ford 1300 fuel filter housing #8
Good, glad it worked. If you find a consumable that is not OEM but works well then my suggestion is to buy couple of extras (specially filters and such) or do take a note of what you bought for future reference. They just never get cheaper. One lift piston seal that I bought under $5 many years ago is now at least $30+
Yea good idea-I’ve got a question about fuel injectors-is there a seal or washer that goes on the injectors between the injectors and the engine block-kinda like a spark plug has
   / Ford 1300 fuel filter housing #10
Yes , there is, item #11 and #12 in the injector parts breakdown attached.
  • 1700 injector.pdf
2020 FORD F-150 XL CREW CAB TRUCK (A59823)
2020 FORD F-150 XL...
EZ-GO Utility Cart (A55851)
EZ-GO Utility Cart...
2014 Dodge Charger Sedan (A59231)
2014 Dodge Charger...
2021 Kubota SVL75-2 Track Loader (A56438)
2021 Kubota...
2012 INTERNATIONAL PROSTAR+ (A58214)
2012 INTERNATIONAL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
