Maybe a new truck Ford or Dodge?
   / Maybe a new truck Ford or Dodge? #201
I’d like to see how the warranties compare between the Ram/Cummins and the Ford/Powerstroke.
In 2020 Ford’s “drivetrain” warranty only included the diesel engine. The rest of the truck was 3/36.
In 2020, Ram included the engine and the rest of the drivetrain in the drivetrain warranty.
Fords powertrain warranty also covers the trans, t-case, & axles just like Ram. You must have been misinformed somehow.
   / Maybe a new truck Ford or Dodge? #202
No
I’m 100% certain that Ford’s warranty was only on the diesel engine. The drivetrain was only shorter 2020. I will bet you a six-pack of beer.
Rams was the entire powertrain the same years & miles.
Ford may have improved their warrant to match Ram.
Ford’s powertrain warranty is 5yr, 60,000 miles. The Powerstroke engine is 5yr, 100,000miles.
Rams entire powertrain Cummins diesel, Aisin transmission, rears, transfer case, etc.) is 5 yr 100,000 miles.
   / Maybe a new truck Ford or Dodge? #203
   / Maybe a new truck Ford or Dodge? #204
But but but Ram...
I know.
   / Maybe a new truck Ford or Dodge? #205
   / Maybe a new truck Ford or Dodge? #206
What made Cp4 fail on Rams and not fords or chevy?
   / Maybe a new truck Ford or Dodge? #207
I believe there was a higher than normal rate of failure on all the CP4 pumps. I am not sure but I think the D Max engine used them also.
   / Maybe a new truck Ford or Dodge? #208
I think GM used those pumps from 2011 to 2016 then quit because of failures. They then started using Denso HP4 pumps. Other makers chose to continue with the Bosch CP4 pumps even with the failures.
   / Maybe a new truck Ford or Dodge? #210
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2013 Ford F-650 Flatbed Truck (A51692)
2013 Ford F-650...
20 ft Angle Boom (A53117)
20 ft Angle Boom...
25077 (A51694)
25077 (A51694)
1985 FREIGHTLINER FLC DUMP TRUCK (A53843)
1985 FREIGHTLINER...
2012 SOUTHERN 130BBL VACUUM TRAILER (A53843)
2012 SOUTHERN...
