What did you do with your Chinese baby digger today?
   / What did you do with your Chinese baby digger today? #331
used mine to set rafters on the greenhouse,--course had to cheat and bolt an angle iron to the side of the bucket! lol! I just used the tooth holes and drilled the angle iron the same hole size. Bolted it on with the tooth bolts. I HAD to take the teeth off to get the bucket to dump dirt anyway. I made better extensions for the bucket that dont bother when dumping. The worst problem I have is bending the teeth. They are soft as butter! Anyway I have a plan to add square bars on each side and shape them to a point on the leading edge then harden them by heating them in the forge like I do plow shares.
Anyway a couple pix of the rafter setting.
Nice work.. These minis are really handy, especially if you get creative..
   / What did you do with your Chinese baby digger today? #333
Didnt get any pix but I used the digger to set logs on the bandsawmill yesterday. It handles MOST of the logs I saw. Its faster than using a skidloader, plus smaller and easier to get around with. I can set them instead of dumping logs on the mill. They do tend to roll off the loader forks.
   / What did you do with your Chinese baby digger today? #334
I hear ya. I have used mine to pile logs, but I still find it easier to use the tractor forks for the WoodMizer and Lucas mills. The forks are the ONLY way to move my slabs when chainsaw milling.
I do fantasize about making a small rotating hyd log grapple for the mini-X. It certainly can lift some pretty heavy logs.
I took delivery yesterday of another Chinese Lil' Digger.. Same color as the L12, but a little stronger and maybe faster. Also it uses Green Energy Technology. Near Zero emissions. Little cheaper also at $55.00, tax and shipping included. Hoping to try it tomorrow.20240218_151303.jpg
Finally, I did the ISO to ASE controls swap. Not as easy as I thought it would be.
Quick question, Do all the Chinese baby diggers have the Torque Marks 0n the fasteners?? my L12 has a Sharpie mark across
all the nuts, bolts, connections. I have been turning wrenches long enough to know when the fasteners I am removing have been torqued to the same spec. or at least within a few pounds.. so far, everything I have removed has been properly torqued.
If you need to remove hydraulic lines from the stack valve, you may need a 17mm crows foot. I had to buy the entire set just to get the 17. really helped to get the lines off.
   / What did you do with your Chinese baby digger today? #339
I pulled the sheet metal off when I switched controls, which made it fairly simple. Pulling the sheet metal off was a bit more work.
   / What did you do with your Chinese baby digger today? #340
That's good news.
I have yet to see those marks. AgroTK is a reseller that gets units from multiple factories.
2014 Jeep Cherokee Latitude SUV (A53424)
2014 Jeep Cherokee...
2016 PETERBILT 579 DAY CAB ROAD TRACTOR (A54756)
2016 PETERBILT 579...
BOMAG BW75AD WALK BEHIND SMOOTH DBL DRUM ROLLER (A52707)
BOMAG BW75AD WALK...
2025 78in Rock Bucket Skid Steer Attachment (A53421)
2025 78in Rock...
2013 Chevrolet Silverado 1500 (A55973)
2013 Chevrolet...
2014 Jeep Patriot SUV (A53424)
2014 Jeep Patriot...
