2manyrocks
Super Member
- Joined
- Jul 28, 2007
- Messages
- 8,668
Until he puts some kind of cutter on the hydraulic motor, I don't know what the actual cutting performance will be.
I suspect there is enough power to run a hedge trimmer cutting head, but I wonder if it wouldn't be cheaper just to attach a two cycle trimmer and use the minix hydraulics to adjust the cutting angle as needed. You could have a pretty long reach provided you didn't get too aggressive and end up bending the trimmer shaft.
I've used a hedge trimmer attachment on a 2 cycle trimmer to mow briars and some light brush. It works, but it is tiring to wield the thing by hand for very long. It not only works, but it is very effective at chopping up a briar patch as well as vines. The minix hydraulics are certainly powerful enough to hold this kind of a cutter all day.
I'm not sure that the hydraulics could spin up a spinning cutter head enough for this kind of work, and it could throw debris at the operator where the hedge trimmer wouldn't do that.
