What did you do with your Chinese baby digger today?
   / What did you do with your Chinese baby digger today?
I ordered this hydraulic ext tube on March 2 from AGT. It was in the mailbox today March 6. I can finally get the hydraulic oil changed, and install my filter. 20240306_140139.jpg
   / What did you do with your Chinese baby digger today? #452
There may be some owners who'd be interested in the measurements of that pickup tube if it is something they could fabricate themselves since it's not currently in stock.
I will get the dimensions and post them. I saw where someone had the tube made and it cost them over $100.
   / What did you do with your Chinese baby digger today? #454
The thread size is probably METRIC crap! See if anybody can find out! Thanks!!
   / What did you do with your Chinese baby digger today? #455
Yeah, it is not clear to me how it is supposed to work, and why the tube is threaded. I posted these pix a long time ago, and my setup uses a long threaded rod, welded at one end, to hold the tube and strainer together. The tube in my photo is welded to the cover plate.
Isn't the tube there just to keep the strainer centered at the bottom middle of the tank?
Yep, it's definitely metric. I did know the dimensions, but I forgot them. I will get the info as soon as I can.
The end of the suction strainer is threaded and screwed onto the fitting in the tank. Remove the strainer, screw on the extension to the fitting in the tank. screw the strainer onto the ext. The extension has male threads on one end and female threads on other.20240306_140148.jpg
The videos show the hydraulic oil and filter (strainer) change, but it also shows how the extension tube is used, as it comes off when he removes the strainer. Probably not much of a video, unless you have an L12.
2004 TRAVIS 48' WALKING FLOOR REFUSE TRAILER (A53426)
2004 TRAVIS 48'...
2004 IH 5600l Snow Plow Truck (A52384)
2004 IH 5600l Snow...
20" Sea Container (A47384)
20" Sea Container...
Pallet of (8) 10 Lug Misc Wheels (A51573)
Pallet of (8) 10...
AMADAS SPC-6 LOT NUMBER 257 (A53084)
AMADAS SPC-6 LOT...
2021 John Deere 333G Compact Track Loader, 390 Hours, High Flow Hydraulics, Ride Control (A53472)
2021 John Deere...
