Massey Ferguson 4707 Fuel Tank removal
   / Massey Ferguson 4707 Fuel Tank removal #1
coffmanjs
2019 Massey Ferguson 4707
Need some help... I have a MF 4707 that keeps displying the fault code 00.1.31. The issue happens quiet often.... the fuel gauge goes to empty and the buzzer comes on. According to the code, it is the in tank sending unit. Anyone have experience removing the fuel tank and replacing the unit? How is it accomplished?
   / Massey Ferguson 4707 Fuel Tank removal #2
Do you have some photos of the fuel tank?
On most vehicles, the fuel tank sending unit is accessible from the top side. Perhaps a ring of bolts/nuts.
So, with some luck, just removing some sheet metal to get to the top of the tank.
   / Massey Ferguson 4707 Fuel Tank removal #3
I have a 2022 4707, so I'm curious about this. Have you talked to your dealer?
There is a Face Book Group called "Massey Ferguson 4700 Global Tractors" that has several Dealers on there that offer advice on Codes and repairs. It doesn't hurt to join that Group and ask your question there.
Here are some pics. The fuel sending unit is visible, but I’m positive the tank needs to be removed. I am hoping someone else has done and can give me their lessons learned. Thanks.
I’ll take pics and document the process and add it to the post. I’ll look into the FB group. Thanks.
   / Massey Ferguson 4707 Fuel Tank removal #6
I didn't realize tanks were being put under the steps of the tractor... until someone was asking about a Branson that had a similar tank. Interesting place to put the tank. Surely an easy place to refill.
I think I'd run most of the fuel out.
Disconnect the fuel lines.
Remove the strap (is there just one strap or a couple of straps?)
I see a big skid plate which is a good thing. I'd check that for more bolts.
Hopefully it will just drop out.
Thanks. I’ll keep everyone posted on progress and document with pics.
   / Massey Ferguson 4707 Fuel Tank removal #8
Probably a long shot but I’d check under your floormat and see if you happen to have a bolt in access panel. I’ve had some tractors that did.
Awesome idea. I’ll check it out. Thanks.
   / Massey Ferguson 4707 Fuel Tank removal #10
Drain it, remove the wheel, unvolt the straps, remove the sender wires and the fuel lines.
2021 CASE IH 345 (A53084)
2021 CASE IH 345...
Oil Well Pump Jack with Motor (A52377)
Oil Well Pump Jack...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2003 Ford F-250 4x4 Reading Service Truck with Liftgate (A53422)
2003 Ford F-250...
