Hydraulic Submersible Pumps
   / Hydraulic Submersible Pumps #11
I went to their link but didn't see it. That's a lot of water, but is about typical for the flow rate that those hydraulic submersible pumps put at low pressure - like pumping out a pond or pool.
Running sprinklers needs more pressure, which means less flow rate. But still a lot of water moved.
I keep coming back to 200 gpm at about 50/60 psi is what is needed.
50/60psi and a 200FT below the ground is my well pump. hmmm
Yes, that would be typical of a good household submersible well pump on 220V. How many gpm do you think your well pump puts out at that psi?
   / Hydraulic Submersible Pumps #13
It's listed in their price sheets.
   / Hydraulic Submersible Pumps #14
sounds like you are designing a fire suppression sprinkler system. your 1/2 inch solids would probably plug up sprinklers. maybe you could run it in zones with a manifold to reduce the flow required by the system.
   / Hydraulic Submersible Pumps #15
He does live out in CO. And fires out there are often enough. I can now realistically understand the need.
Often show up used on govdeals. Local fellow had one for over a year on marketplace $200 obo but just checked and no longer listed.
Yep. That's the right type of pump. Though that one is sort of an oddball, though it could be made to work. Those submersible pumps just never got to be popular. There are marine versions which are used for washing down tankers and as bilge pumps on big ships.
I wonder if 4wd TLBs are why we don't hear much about UniMogs anymore?
   / Hydraulic Submersible Pumps #18
Several listed with brands like Stanley or Greenly. Used by utilities to dewater underground services. Often have compatible hydraulic chainsaw, cutoff saw, hammer, etc. Definitely a safety factor over electric or gas powered for personal.
They do show up used, usually dirty out of utility vehicle sales. Getting them before they are sold as scrap the trick.
Have a soft spot for Unimogs. Got to operate a loader/backhoe version at ORNL rigged to be fully remote controlled. Experimental UXO or mine detection and recovery. Long before the current drone capabilities.
   / Hydraulic Submersible Pumps #19
The major issue using one of these hydraulic pumps is a hydraulic oil leak
frying the tractor and polluting the water.
The HALE SUPERCHIEF floating fire pump works in 3 inches of water.
It has a 2.5 inch connection and will pump 420 gallons per minute at
50 PSI.
Right now it is $4,055.00 plus tax and freight from the folks at FELD FIRE.
The current price is 10% off.
Resistance to fluid flow creates pressure.
This HALE self priming centrifugal pump can pump water 20 feet up hill @ 50 PSIG
if that is what your major concern is.
If you are using this water to irrigate crop land using rotating gun type sprinklers
and aluminum delivery pipe you are going to need much more flow per second.
The small traveling reel type sprinklers have smaller hoses and rain guns.
Is there any reason you cannot use a portable fire pond at the upper elevation?
Please tell me more about what you think your needs are.
50 PSI.
Leonz, you raise some interesting questions.
The pump needs to pump 30 feet uphill to be usable - and then have enough pressure to run several rotating nozzles with 3/8" nozzles to cover several hundred feet.
As nice as the Hale looks, I was hoping for something with about double the SuperChief's capacity.
Local water sources here are used by a number of traditional mining and other businesses. Including a lot of irrigated agriculture. This is a larger stream and can support the use, but I do not know what the requirements are for isolating or maintaining a submersible hydraulic pump.
It may be that some amount of isolation or inspection are needed. Thanks for the input, the submersible idea definitely needs looking into before going any farther with this project.
rScotty
KOMATSU PC490LC-11 EXCAVATOR (A60429)
KOMATSU PC490LC-11...
2008 TCE MANUFACTURING 20GN GOOSENECK GEN TRAILER (A58214)
2008 TCE...
Brent 320 Auger Wagon (A59814)
Brent 320 Auger...
2018 Autocar ACX Xpeditor T/A Hercules Front Loader Garbage Truck (A55852)
2018 Autocar ACX...
32in. Tilt Grading Bucket Mini Excavator Attachment (A59228)
32in. Tilt Grading...
1990 Bayliner Trophy Center Console Boat w/ S/A Boat Trailer (A59231)
1990 Bayliner...
