Kubota L3710 Will not Crank
   / Kubota L3710 Will not Crank #1
Suburban Plowboy
FL
Kubota L3710
I have a Kubota L3710 with HST. It began refusing to crank this year.
I noticed that the tractor would start when I jiggled the F/R pedal, so I thought there had to be a sensor somewhere that prevented the tractor from starting unless the pedal was disengaged. I have since been told this model has no such sensor. I could not find one when I crawled under it, and I can't find one on diagrams.
Today I needed to pull my Dodge Ram out so a tow truck could take it in for work, and the Kubota started acting up again. I finally had to give up and pull the Kubota and truck with a JD garden tractor. I told the tow guy the Kubota would start right up as soon as he left, and sure enough, that's what it did. Irritating.
The tractor runs until I shut it off. The mystery issue does not shut the engine down. Someone suggested there could be a problem with the neutral safety switch. I don't know if that would shut a running engine down.
What is the most likely problem?
The dash lights turn on, except for the glow plug light. When the tractor actually cranks, the glow plug lights up. I think.
   / Kubota L3710 Will not Crank #2
Here's s start. I did have a post somewhere with pics:
   / Kubota L3710 Will not Crank #3
Here's the thread I was looking for:
   / Kubota L3710 Will not Crank #4
There's a safety switch connector on the starter on my 1999 L3710 that acts up sometimes.
Thanks for the replies. Right now, this one is looking promising.
Will the safety switch shut the motor off? If so, it's not my issue.
Thanks. I'll try to find it.
   / Kubota L3710 Will not Crank #8
There is an HST pedal switch and clutch safety switch off the L10 series tractors. On my previous L3410, the clutch had to be depressed to start, and I believe the HST pedal had to be neutral to start.
Neither of these switches will affect the running tractor, as I used to creep the tractor from outside when attaching implements.
A guy who claims to know about this showed me parts diagrams and says the L3710 has no switch on the F/R pedal.
   / Kubota L3710 Will not Crank #10
Straight out of the workshop manual:
CATERPILLAR 255 SKID STEER (A52709)
CATERPILLAR 255...
HYDRAULIC THUMB CLAMP FOR MINI EXCAVATOR (A58214)
HYDRAULIC THUMB...
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2016 Case Magnum 310 (A60462)
2016 Case Magnum...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
3Pt 4' Harrow (A59814)
