Looking for inexpensive AW46 - Hydraulic Oil
   / Looking for inexpensive AW46 - Hydraulic Oil #91
Cheapest I’ve found is old KFC oil. Gotta filter it some though. 😂
I agree it is hard to pin down OEM requirements compared to aftermarket oils. The most annoying part is I’m 99% sure no equipment company actually makes the super duper oem only fluid they sell themselves.
   / Looking for inexpensive AW46 - Hydraulic Oil #92
I dug DEEP into THEIR specs, and the fine print said, "not for heavy duty hydraulic use".
My use is intermittent, non-commercial, so I’m not worried, but curious, where it says that?
   / Looking for inexpensive AW46 - Hydraulic Oil #93
It was actuallty, cuts to the chase. Cheap is cheap no matter what it pertains to.
No. It was mean spirited and bitter. Not everyone has the same amount of disposable income you and I do. Sometimes it is necessary to be frugal. My dealer literally told me as long as the oil says it meets the standard in my manual the manufacturer doesn't care what brand. Hydraulic Oil changes are expensive if you insist on mobil delvac, which doesn't even claim to meet ap gl-4 and isn't aw46 wieght . It is just marketed as premium hydraulic oil. And don't even mention the "303" bs or the j20c marketing. At least TSC has gl-4 and aw46 on the container......
   / Looking for inexpensive AW46 - Hydraulic Oil #94
Al
Isn’t gl4 a stinky gear oil not hydraulic fluid?
   / Looking for inexpensive AW46 - Hydraulic Oil #95
That's bullsnot and far as disposable income is concerned, I'm on Social Security, how's that.
There is always a difference between cheap lubricants and expensive ones, if, you bother to read the fine print.
   / Looking for inexpensive AW46 - Hydraulic Oil #96
Al
Gl4 is a specification for oils used in transmissions ad all tractor hydraulic oil is. It is generally required for synchromesh and hst compact tractors
   / Looking for inexpensive AW46 - Hydraulic Oil #97
I don't disagree there's a difference. But I think your machine will outcast you on cheap oils.
   / Looking for inexpensive AW46 - Hydraulic Oil #98
Yeah the stinky stuff. I’ve seen it in front axles but not hydraulic systems who calls for gl4 spec for hydraulics?
   / Looking for inexpensive AW46 - Hydraulic Oil #99
Regarding GL-4 rating.. I think you’re mistaking their “Premium Tractor Hydraulic fluid” rating with their ISO 46 hydraulic fluid.
   / Looking for inexpensive AW46 - Hydraulic Oil #100
If the fine print on the label lists "meets or exceeds the requirements for (insert machine brand)", thats' as good as you get.
  • Good Post
Reactions: D&D
2016 FORD F-250 PICKUP TRUCK (A52576)
2016 FORD F-250...
2021 Delta Redirective Crash Cushion 75000 (A51692)
2021 Delta...
2010 Chevrolet Impala Sedan (A51694)
2010 Chevrolet...
FAKE (A52472)
FAKE (A52472)
2018 Nissan Sentra Sedan (A51694)
2018 Nissan Sentra...
2004 Honda Odyssey Van, VIN # 5FNRL189X4B025339 (A51572)
2004 Honda Odyssey...
