3510 Front inner tube recommendations or 'No-Flat' fill product?
/ 3510 Front inner tube recommendations or 'No-Flat' fill product? #1
DiskDoctr
Western PA
Mahindra 3510
About 8hrs on new tires and tubes and one tube burst. 28 x 8.50 x 15 R4 industrial tires. Apparently cannot handle the front loader weight.
We wire brushed and cleaned entire wheel to make sure no burrs. So now looking for heavy duty tube and/or no-flat product that will handle the weight.
Also- For decent price/condition, I'd consider buying new front wheels as well.
Tips, products, vendors?
/ 3510 Front inner tube recommendations or 'No-Flat' fill product? #2
My Hy-Run tubes DISSOLVED when I tried to fix a burst seem with 'rubber cement' and a blowout patch.. Try a different brand. Carlisle has worked well for me. Yes, welded wheels intended to be used with tubeless tires often have weld flash that will puncture a tube. I mark the position of the tire and tube when I get thorn punctures so I can I.D. the source.
/ 3510 Front inner tube recommendations or 'No-Flat' fill product? #3
Recently I had to buy some inner tubes for ancient trailer wheels that were all rusted and was amazed that I couldn't find any made here in the USA that would not quickly disintegrate. EVERY one I looked at on line said "Made in China" and most were brands I had never heard of. Finally came across some Firestone tubes that were supposedly made in USA. This is what I found when I pulled one out of the package:
/ 3510 Front inner tube recommendations or 'No-Flat' fill product? #4
Did the tube blow out or did the tire blow out.
As far as stop leaks I have been pleased with the performance of this brand;
I found a pic I took of the tube I took out of it. It had been in the tires for about 10 years or more. One was even patched once and put back in.
I ordered two replacements to be here by the end of the week. My tire guy couldn't get them right now, so Amz* to the rescue!
Amazon.com
/ 3510 Front inner tube recommendations or 'No-Flat' fill product? #6
Wow! If the ones I just installed last at least 10 years I'll be a happy man!
Tube. Tires are new
Carlisle Trac Chief 28/8.50-15 C​
The tubes are supposed to have valves designed for fluid/ballast.
The stuff you linked is preventative to stop punctures, right? How many are needed for the tire tubes?
/ 3510 Front inner tube recommendations or 'No-Flat' fill product? #8
Tube. Tires are new
/ 3510 Front inner tube recommendations or 'No-Flat' fill product? #10
Translation: "How much of the stuff do you put in a tube?"
So 28x8.50-15 would be 28 x 8.50 = 238 / 4 = 59.5 or about 60 oz.
/ 3510 Front inner tube recommendations or 'No-Flat' fill product? #11
Are you sure the rims & tires are correct for your loader tractor ? My 4110 came new with 12- 16.5 NHS R4 10-ply tubeless tires (Titans). I have replaced them twice over the years with the same size in 12-ply tubeless (China) and never had a bit of problem other than a loose valve core once that let the air out of one. You can't even tell the tire is flat unless you put a good load in the bucket they are so stiff. I don't load my front tires, just the rears with 50/50 methanol & water mix. I have done tremendous amounts of heavy loader work with it over the years.
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2019 GALYEAN...
JOHN DEERE 544G WHEEL LOADER (A58214)
JOHN DEERE 544G...
Caterpillar 928G Articulated Wheel Loader (A59228)
Caterpillar 928G...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
