How many of you found garbage buried around your place from past owners?
   / How many of you found garbage buried around your place from past owners? #131
Fence wire is probably worse though.
There were so many old fences on our place in CA. I made a lot of dump runs. Old air photos showed that a lot of it was pasture in the '40s and 50s. It's forest or thick, and I mean really thick, brush now.
When we moved in we went exploring. My wife discovered a trash pile under some bushes. It was winter so there were no leaves, making it easier to see. She had to crawl through the bushes to get to the pile. She found some old pots with holes in them and a 1946 license plate.
Then a week later she found that the bushes she'd been crawling through were poison oak.
   / How many of you found garbage buried around your place from past owners? #132
What a welcome to the neighborhood! I lived for a while in your old neighborhood, and looked after my parents cocker spaniel for a year. (Well, ok sent it through canine boot camp for the year. Ill behaved doesn't begin to describe it.)
On one of my first hikes with him towards the coast, as we got back to the car some folks turned up with a big, not very friendly Rhodesian ridgeback cross, so I scooped my dog up and held on to him tight to keep him from getting into trouble, or eaten, as neither dog looked particularly well behaved. Two days later, I had a six inch wide three inch high smear across my stomach as the dog had gotten into some poison oak sap. Being used to toughing it out with poison ivy, I thought no problem. Mistake. I went through a couple ounces of topical steroid cleaning that up, and I have had an eagle eye for poison oak ever since.
All the best,
Peter
   / How many of you found garbage buried around your place from past owners? #133
Was there a reason you filled the wells? Was it a permit issue, or was it you didnt need them, or where they actively collapsing or similar? Unless forced too, I wouldn't full them, id just leave them be
I was worried about someone or something falling into them. These are old hand-dug wells. Not very deep, it's rarely more than 12' to bedrock here. The one I filled with sand was about 8' deep and 3' in diameter.
   / How many of you found garbage buried around your place from past owners? #134
One of the misconceptions of my youth was that those 3' diameter, stone lined wells were dug by a 4'10" tall well digger using short-handled picks and shovels. I now realize a hand-dug well was usually an open pit, the diameter of which was determined by soil conditions (see angle of repose) so that the risk of collapse was acceptable. Once water was found, they would continue digging as long as they could practicably remove the water (by buckets or pump). At some point the diggers would lay a stone base and start constructing a cylindrical stone wall, backfilling with stones on the outside (in the pit). This stone provided voids to hold a reservoir of water larger than the diameter of the casing and provide scaffolding for the stone-masons laying up the lining. As the height rose they would use smaller and smaller stones, finer and finer sand, and then clay (if available) or even a tar-paper membrane in a cone around the lining to keep surface water from flowing into the well along the lining. An earthen cone was often extended above the surrounding surface grade depending on the finances of the owner or the patience of the crew.
   / How many of you found garbage buried around your place from past owners? #135
A neighbor still has a dug well unfilled, fortunately there are no young kids nearby. How many critters are at the bottom of it, I don't know. It does have boards partially over the raised portion.
   / How many of you found garbage buried around your place from past owners? #136
Before I filled that well I rented a trash pump and pumped it out, then put a ladder in and climbed down to check it out. What I noticed is that while there was room to stand, it was almost impossible to move without bumping my butt against the wall. The wall was cold and my butt got cold.
There's a Tom Waits song where he talks about it being "colder than a well-digger's ass." I think I know what he means.
   / How many of you found garbage buried around your place from past owners? #137
There is a reason many utility company's have a max manhole riser rings on top of the eccentric cone. Many MH lids are 24" and if the riser rings add up to much, it becomes impossible to bend your knees on a ladder. You can physically fit, just not move the legs.
   / How many of you found garbage buried around your place from past owners? #138
Now you guys are giving me claustrophobia!
   / How many of you found garbage buried around your place from past owners? #139
We left a laser target for a pipe laser in a dead end run of 18" storm drain. Not truly dead end, but laid to the edge of asphalt for next phase of traffic shift. Anyways, we were going to just dig it back up, and one of the guys actually crawled it, about 48 ft, to get the target. Its not so much a crawl, as a worm action, and then the same in reverse... Im not as skinny as him, but not just No, but Heck no... 24" yeah, id crawl, 30" sure, but 18", naa
Had a helper crawl between plywood and metal building panels, 8.5" wide... to get a screw gun he left in the wall, only 8 ft into the wall, but still
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2019 Deere 550K (A53317)
2019 Deere 550K...
2022 Wacker Neuson PDT2A 2in Portable Diaphragm Pump (A55851)
2022 Wacker Neuson...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2020 FREIGHTLINER CASCADIA 126 TANDEM AXLE SLEEPER TRUCK (A59575)
2020 FREIGHTLINER...
JLG 15 MVL MANLIFT (A58214)
JLG 15 MVL MANLIFT...
