Is this a good deal
/ Is this a good deal #1
1930
Brandon/Ocala Florida
Kubota B6100E Kubota L 2501 Kubota T1460
Someone I know offered me this first choice finish mower for 75.00. I know zero about finish mowers.
I know it needs wheels, at least a pulley and belts. Don't know what else.
He knows nothing supposedly about it. He traded it for some paint work.
Deck width is 5 foot. I dont even know if its missing parts to hook it up to my small kubota B series 2 wd tractor.
Looked underneath it and deck is fairly clean with minimal rust. Blades seem to turn freely, possibly smoothly..
Can you guys look at the 2 pictures and tell me if my tractor is big enough to work it.
Thanks
Cant find an identification plate but maybe I didn't look hard enough
/ Is this a good deal #3
For that price you can’t go wrong but I don’t think your tractor is big enough.
/ Is this a good deal #4
The PTO shaft alone is worth $75. It is large for your tractor, but might work if you drive slooowly. I would buy it, use it, look for a 4 foot model, and then sell this one.
/ Is this a good deal #5
/ Is this a good deal #6
12hp & 60" is 12" too far.
You can get away with a 48" mower but 60"?
Your tractor doesn't have the hp to turn the gear box and spindles with any sort of efficiency.
Like airbiscuit says:
Buy this and sell it. The profit will buy a nice 48" for you to use.
Can someone confirm by looking at pics that nothing major is missing/ that I can hook it up to my B series or my L series without having to buy a ****ton of parts.
I really dont have the money right now to get involved with something that's gonna require alot of cash outlay just to hook up to my tractor
/ Is this a good deal #9
I don’t see the second half of the pto shaft in the picture.
I'm on my property right now. Internet is almost non existent otherwise I'd be researching this more myself
/ Is this a good deal #12
Based on what you've posted I would buy it and decide what to do with it afterwards. To answer your original question, yes that is a good deal. As others have pointed out if you don't keep it you should be able to sell or trade it as it sits now, and still come out ahead.
Pulleys are cheap, belts are maintenance items anyways.
I see the wheels alone are 100 a piece. 1 is missing completely and I think the other 3 are badly damaged.
Sometimes a good deal isnt so good.
I have to wonder what the mower cost new?
168 for the drive pulley that needs replacing. The parts link is super handy. Im glad I'm able to open it
/ Is this a good deal #15
The mower gets good reviews elsewhere on TBN. If you can get a 5/8" to 1/2" bushings (a piece of 1/2? copper pipe?), these $9 wheels could be made to work.
1" x 2-1/2" Solid Rubber Tire
I went back and looked at it again, its within driving distance of my tractor. I took it apart and brought it home, Im home now so I can do a better job of finding parts/info.
The second look convinced me it is in overall pretty good shape. Im in no rush for needing to use it so I figured for the 75.00 I can piece whats missing or broken over time.
Ive read its Italian made and Ive also read American made?
Ill post some more pictures. Thanks
/ Is this a good deal #18
I used to mow my yard with a ford 1220 with a woods rm 59 , plenty of powerwith 17 gross hp. Cut lots of tall grass with it to . As long as the spindles are good you can get tires for less than 100 bucks , I would buy it .
/ Is this a good deal #19
A post from 2011 by tillboy2001
My quick review of the First Choice / Sicma 72" finish mower
History: I went from a Bush Hog RDTH72 finish mower...then to a Frontier 72" rotary cutter....then to the First Choice 72" rear discharge finish mower (Made by Sicma, the Italian company). I had the dumb idea of getting a rotary cutter since I thought it would be better for the field. Bad move. The rotary cutter was much longer, was a pain to maneuver, dug into the ground when going through certain dips and in general, cut like crap. Sure, it's a rotary cutter so it's not going to cut like a finish mower, but I didn't realize just how bad it was compared to a finisher mower.
Anyway, after selling the Frontier rotary cutter, I picked up a First Choice 72" finish mower from Ken Sweet at Sweet Tractor in KY. Since I'm in KY and only about 3 hours away, I went down and picked it up. It fit perfectly (sideways) even with the wheels on, in the back of my F150. After using it for a few hours now, I'm very happy with it. It cuts great, is quiet and sticks to the contour of our rolling hills and dips like glue and does not scalp. I did get the add-on front anti-scalp roller too.
The only thing I'd like that this model doesn't have is a self-adjusting belt (you have to manually adjust it if it gets loose...but honestly, how often would you really need to do that?).
I put some photos in my member photos: First Choice / Sicma 72" Finish Mower - TractorByNet.com Photo Gallery
/ Is this a good deal #20
I have one that looks just like it. Its a taylor made in italy. I dont think their made anymore. at least i dont know of anyone selling them and i cant find parts
2024 DODGE RAM 2500 HEAVY DUTY PICKUP TRUCK 4x4 (A59912)
2024 DODGE RAM...
Trimble EZ Guide 500 Monitor (A63117)
Trimble EZ Guide...
2018 VOLVO SD115B PADFOOT ROLLER (A64279)
2018 VOLVO SD115B...
2023 Kubota L6060HST Compact Utility Tractor (A63688)
2023 Kubota...
2021 PETERBILT PB337DUMP TRUCK (A63276)
2021 PETERBILT...
2003 VOLVO VNL 6X4 T/A SLEEPER TRUCK TRACTOR (A59908)
2003 VOLVO VNL 6X4...
